torque converter question #166876
12/13/08 05:38 PM
12/13/08 05:38 PM
Hartselle AL
67MIke Offline OP
67MIke  Offline OP
Hartselle AL
I was putting my truck together when I ran across this problem. The old converter was for a 440 and I'm using a 400 now. I took the 400 tq and all, but it doesn't fit my trans.. The fork that goes in to the tranny are bigger with 400 than the one for the 440.
I was just going to use the 440tq with 400 engine, but it looks like the 440 tq has two weights by the tq drain. what will work...
Thanks MIke
Re: torque converter question [Re: 67MIke] #166877
12/13/08 06:50 PM
12/13/08 06:50 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Both convs should fit the trans. Did you measure the lugs on both? Sometimes they can be a pain to engage.
To answer your question though, the 440 TC W/ the weights is for an externally balanced engine. Using it behind an internally balanced motor will cause nasty vibrations. It may be possible to remove the weights but you will have to be carefull not to cause a leak.
Re: torque converter question [Re: 67MIke] #166878
12/13/08 08:30 PM
12/13/08 08:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The size of the weights on a cast crank 440 converter is the same as those on a cast crank 400 converter so they will interchange.
Some drive slots are larger than others but all are larger than the drive lugs in the pump so that's not the reason it won't go in.
Re: torque converter question [Re: John_Kunkel] #166879
12/13/08 08:52 PM
12/13/08 08:52 PM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
sometimes these can be a real pain to line up. we've had to stand tranny's on end occasionally to line the converters up. also, make sure you have the correct number of splines in the converter and input shaft. 67 and newer are finer splined.
Re: torque converter question [Re: 67MIke] #166880
12/13/08 10:53 PM
12/13/08 10:53 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Not sure what fork you mean but did you spin the converter to get it on and did you try the one you orignally had on with the 440.
Re: torque converter question [Re: 68Fastback] #166881
12/14/08 09:49 AM
12/14/08 09:49 AM
Hartselle AL
67MIke Offline OP
67MIke  Offline OP
Hartselle AL
thanks for the help. I did spin the T Q to make sure it was in all the way. It seems to fit, I just didn't like the drive lugs(?) were a different size. Both engines are cast, but the 400 damper is thinner than the 440...
So should i cut the weights off the 440 T Q or... let it roll as is ....
Re: torque converter question [Re: 67MIke] #166882
12/14/08 10:29 AM
12/14/08 10:29 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Unless someone has put a 383 crank in the 400 it should need a external balanced converter. Not sure if it takes the same weights as a 440 though.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: torque converter question [Re: MoparforLife] #166883
12/14/08 10:38 AM
12/14/08 10:38 AM
Hartselle AL
67MIke Offline OP
67MIke  Offline OP
Hartselle AL
Umm. Thanks . I think I forgot to mark my flex plate too.... This is looking towards a messy situation.. Moron alert .. Sorry first one I have done
Re: torque converter question [Re: 67MIke] #166884
12/14/08 10:55 AM
12/14/08 10:55 AM
Hartselle AL
67MIke Offline OP
67MIke  Offline OP
Hartselle AL
after rereading my posts and the others, the TQ does go in, IU was just worried about the drive lugs being a different size. So it should work then, I was worried about slop in the drive lugs...
Re: torque converter question [Re: 67MIke] #166885
12/14/08 04:08 PM
12/14/08 04:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If in doubt measure from the face of the bellhousing to the one of the drive lugs, should be back at least 1/2".
Even though the cast crank 440 and 400 are both externally balanced the dampers aren't the same, the cast crank 400 damper is thinner than the 440.
Re: torque converter question [Re: John_Kunkel] #166886
12/14/08 07:24 PM
12/14/08 07:24 PM
Hartselle AL
67MIke Offline OP
67MIke  Offline OP
Hartselle AL
thanks guy's. I just used the 400 TQ,. fit good and spun okay. We'll see....
