Re: 727 Speedometer Pinion - Where To Buy One?
[Re: Menzaero]
#166847
12/13/08 04:29 PM
12/13/08 04:29 PM
RapidRobert
our parts for sale sections probably transmissions
[Re: Menzaero]
#166851
12/13/08 08:24 PM
12/13/08 08:24 PM
Posts: 25,933 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The math for the combo in the OP comes out to 34.4, when the decimal is less than .5 it's best to go with the smaller gear, this will make the speedo read a little high which avoids speeding tickets.
The number for some gears has changed, the new one for the 34 is 52068156.
[Re: 1E2C]
#166855
12/13/08 10:45 PM
12/13/08 10:45 PM
RapidRobert
do you have an actual measured 27" on your rear tires(s)? by putting a flat piece of stock on top of one of your rear tires & measuring from the bottom side if it down to the ground. tires of the same size but different brands will have a different height/circumference. Just want you to get it right the 1st time.
[Re: Menzaero]
#166857
12/14/08 02:54 AM
12/14/08 02:54 AM
Posts: 2,673 Northern MN
1E2C
Northern MN
Mechanical speedo will be the long shaft, electronic speedo is the short shaft. How to tell? If it's an electrical connector with 3 wires hooked up it ain't mechanical. If it's got the sleeved cable coming off it ain't electronic. I think the short shaft speedo came about in the early 90's with the proliferation of computerization, but at any rate I'd be willing to wager a small confectionary yours is the mechanical speedo that will use the long shaft. Mike Oh, here's a pic showing the diff.....
[Re: 65Sat440]
#166859
12/14/08 10:37 AM
12/14/08 10:37 AM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
I just ordered one from Yearone, listed for $29.95. They called and said the price is now $69.95!! I cancelled.
Let me know if you find a source for less $...
I paid the 29.95 from them for one a few years ago...only to find out weeks later it was on backorder....I canceled it and found a used one on ebay.
