8 bolt dodge rims? #1668147
09/06/14 03:03 PM
09/06/14 03:03 PM
London Ontario Canada Eh
Dono Offline OP
Dono  Offline OP
The boy is looking at taking the duel wheels off the back of his truck and putting on one large wide tire on the dodge diesel truck. Is there an off the shelf rim manufacture that makes such an animal and how wide can we go with a rear tire?
Cheers Don.
Re: 8 bolt dodge rims? [Re: Dono] #1668148
09/07/14 09:05 AM
09/07/14 09:05 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
You need to give a little more info. As far as off the shelf, anything wider than 12", no. As far as tires, Mickey Thompson makes some pretty wide ones but none are E-rated. So what is he planning to do with said truck?
Re: 8 bolt dodge rims? [Re: redraptor] #1668149
09/07/14 11:56 AM
09/07/14 11:56 AM
Dono Offline OP
Dono  Offline OP
Ok the boys truck is more of a trar.... truck/car that he drives to school and around. There is large stacks in the truck box so the box is just used for little light loads.
She is a first gen cummins diesel stick. When I have some time I will pull the rear wheels off and measure up what room there is and what offset is needed.
Tires I know are quite easy and M/T will be the tire of choice. Just wondering if there has been anyone on here that may have looked at doing this to an 8 bolt dodge diesel. I would expect having the two rims it would need to be 14"s plus anyways.
Cheers Don.
Re: 8 bolt dodge rims? [Re: Dono] #1668150
09/07/14 12:27 PM
09/07/14 12:27 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Its a Dually he can run a 16" wide rimbgiven the correct bs
Re: 8 bolt dodge rims? [Re: 76dodgeboy] #1668151
09/07/14 02:44 PM
09/07/14 02:44 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
you can use super single wheels and tires off a tractor trailer with bolt on rim adaptors
Re: 8 bolt dodge rims? [Re: NoFrills] #1668152
09/07/14 08:14 PM
09/07/14 08:14 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Yep. Given you have the Big Wheel adapters. Seen pics of a 91-93 running them
Re: 8 bolt dodge rims? [Re: 76dodgeboy] #1668153
09/08/14 09:10 PM
09/08/14 09:10 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
The rims in the pic are 19" wide and that 9 1/4 is dimensionally the same backing plate to backing plate as my dana 80. The outside dimension of the tire is the same too on my dually. This sounds like an incredibly expensive experiment to a non problem.
Re: 8 bolt dodge rims? [Re: Dono] #1668154
09/09/14 09:18 AM
09/09/14 09:18 AM
Guitar Jones Offline
That is a 2nd gen truck.
Re: 8 bolt dodge rims? [Re: Guitar Jones] #1668155
09/09/14 08:44 PM
09/09/14 08:44 PM
Bowling Green KY / Nashville, ...
300by500 Offline
300by500  Offline
Yep. THIS is a First Gen...
Re: 8 bolt dodge rims? [Re: 300by500] #1668156
09/09/14 09:54 PM
09/09/14 09:54 PM
dogdays Offline
dogdays  Offline
Tell you what, just send me the money and get him used to driving the truck with the duals. We'll both be happier!
R.
Re: 8 bolt dodge rims? [Re: dogdays] #1668157
09/10/14 08:36 PM
09/10/14 08:36 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Lol. Here we go again.
When Talking to DIESEL Guys First gen is refered tobas the Engine Not truck. When talking Gas trucks First gen is referee to as the Ram.
I think the term First or sececond gen is Dumb and reminds me of craperos and imports
Re: 8 bolt dodge rims? [Re: 76dodgeboy] #1668158
09/10/14 09:14 PM
09/10/14 09:14 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Wow. I had no idea. What's the difference in the '93 diesel and '94 diesel engines?
Re: 8 bolt dodge rims? [Re: redraptor] #1668159
09/11/14 04:22 AM
09/11/14 04:22 AM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
A 93 will have a VE injection pump and a 94 will have a P7100 injection pump, then a 98.5 will have a VP44 injection pump AND 24 valves.
Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
Re: 8 bolt dodge rims? [Re: 76dodgeboy] #1668160
09/11/14 09:10 AM
09/11/14 09:10 AM
You can think it's dumb if you want but the terms are there to differentiate the various incarnations, and there are distinct differences. Yes, even the wheels. Take a look over at dieseltruckresource.com and you'll see how they are split up.
Re: 8 bolt dodge rims? [Re: Guitar Jones] #1668161
09/11/14 12:20 PM
09/11/14 12:20 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
The terms will always be present. Nothing I can do about it. I just never relized it was so difficult to say 92 250 with a cummins etc lol. This topic is brought up about once a week now on facebook. Those that go buy the 81-93 Ram being being first gen are technically incorrect. Ive owned/own3 1980 truck that they said Dodge Ram on the tailgate and had the white leaping ram on the fender.Plus some if not all 1980 brochures say Ram on them. Either way its a term those like me that could care less about must deal with.
Sorry for veering off topic
Re: 8 bolt dodge rims? [Re: 76dodgeboy] #1668162
09/11/14 08:55 PM
09/11/14 08:55 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
You tell'em Harry! They are still D series pickups. Wonder what confusion will happen when Ram isn't a stand alone brand?
Re: 8 bolt dodge rims? [Re: 76dodgeboy] #1668163
09/14/14 09:44 AM
09/14/14 09:44 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Because then you get those funky years where some have a 12v, and some have a 24v. or where some have a 5.9 and some have a 6.7
**Photobucket sucks**
