94 Dakota Ignition #1667314
09/03/14 05:14 PM
09/03/14 05:14 PM
South of Seattle
MBigDaddyM Offline OP
South of Seattle
Some part of the ignition has failed. I believe it to be the tumblers or part of that assembly. When you turn it past start it will just crank and crank, sometimes though when you turn the key past start it will go forward one more click (one side of the key pointed down at the bottom of the dash the other pointed at the steering wheel.) Sometimes it gets stuck, sometimes it doesn't. Any ideas? Help!
Will the last one leaving the US please turn out the lights.
Re: 94 Dakota Ignition [Re: MBigDaddyM] #1667315
09/03/14 05:21 PM
09/03/14 05:21 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
replace the switch. The key cylinder is probably still good if the tab hasn't broken off the end. What you are describing doesn't sound like tumblers because all they do is allow the key to operate.
Re: 94 Dakota Ignition [Re: stumpy] #1667316
09/03/14 05:30 PM
09/03/14 05:30 PM
South of Seattle
South of Seattle
Can that part of the column be taken apart without deploying the air bag? The last time I had to do this was in my 73 Dart Sport. So a "modern" column is new territory for me. -BD
Re: 94 Dakota Ignition [Re: MBigDaddyM] #1667317
09/03/14 05:44 PM
09/03/14 05:44 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
do an online search on "how to replace A 94 Dakota ignition switch". You should get the info you need.
