Alumn. roller rockers question #1667225
09/03/14 09:23 AM
09/03/14 09:23 AM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
Anyone had any experience with Speedmaster 1.5 roller rockers? Good, bad, or ugly? I've always used Crain, or Harland sharps. Would these measure up (or at least be adequate/trust worthy)?
Thank you, my Mopar brothers.
Re: Alumn. roller rockers question [Re: bigblock340power] #1667226
09/03/14 10:32 PM
09/03/14 10:32 PM
Elk Grove, Calif.
Elk Grove, Calif.
Nobody!?
Re: Alumn. roller rockers question [Re: bigblock340power] #1667227
09/04/14 12:28 AM
09/04/14 12:28 AM
IN
ahy Offline
ahy  Offline
IN
I've never heard of them. Can you post a pic or link?
Re: Alumn. roller rockers question [Re: ahy] #1667228
09/04/14 12:37 AM
09/04/14 12:37 AM
Elk Grove, Calif.
Elk Grove, Calif.
HYG.
http://www.ebay.com/itm/171429034077?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648
Re: Alumn. roller rockers question [Re: bigblock340power] #1667229
09/04/14 01:28 AM
09/04/14 01:28 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Run Forest Run!!!!
Re: Alumn. roller rockers question [Re: bigblock340power] #1667230
09/04/14 01:33 AM
09/04/14 01:33 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
More cheapo, low-quality Chinese junk..
If U are just running a stocker/street cruzer, than maybe U can get by...
But if looking for reliable, high performance and endurance keep shopping..
Just my $0.02...
Re: Alumn. roller rockers question [Re: Sinitro] #1667231
09/04/14 06:02 AM
09/04/14 06:02 AM
Elk Grove, Calif.
Elk Grove, Calif.
Your is probably all it's worth.
Re: Alumn. roller rockers question [Re: bigblock340power] #1667232
09/04/14 09:38 AM
09/04/14 09:38 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I went with a kit from Mancini racing last year. They offered a set of lower priced arms made by Harland Sharp. They have been working fine with both the 509 cam and the Lunati going on 3000 miles. 1.6 ratio. I think mine were around $425 They don't gain in lash, run pretty quiet even with the solid lifter cam and use ball/ball type pushrods.
Re: Alumn. roller rockers question [Re: Kern Dog] #1667233
09/04/14 01:46 PM
09/04/14 01:46 PM
dogdays Offline
dogdays  Offline
Equals ProComp with their new name. I wouldn't gamble on them.
Rockers are the last place to save money. A failure, discussed here many times by victims, can be catastrophic.
R.
Re: Alumn. roller rockers question [Re: bigblock340power] #1667234
09/04/14 03:16 PM
09/04/14 03:16 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
If your engine is only worth ...
Then run them but suggest U keep the revs < 3K..
Just my $0.02..
Re: Alumn. roller rockers question [Re: bigblock340power] #1667235
09/04/14 05:38 PM
09/04/14 05:38 PM
AndyF Offline
AndyF  Offline
It costs about $500 for a decent set of aluminum rocker arms. Steel or nodular rocker arms can be made for a little less money. $185 rocker arms are going to be garbage regardless of who makes them. That just isn't enough money to buy good materials and perform high quality machining operations. It takes resources (money) to buy high quality tools and to properly machine and heat treat parts.
Re: Alumn. roller rockers question [Re: bigblock340power] #1667236
09/05/14 12:02 AM
09/05/14 12:02 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
A pair of Harland Sharp shafts costs more than that whole setup. http://www.summitracing.com/parts/csp-pr7001-78
What does that tell you?
Re: Alumn. roller rockers question [Re: GomangoCuda] #1667237
09/05/14 02:54 AM
09/05/14 02:54 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I believe speedmaster is the name Pro-Comp Electronics puts on their rockers nowadays.
