Page 2 of 3 1 2 3
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: MRMOPAR622] #1666608
09/03/14 08:55 PM
09/03/14 08:55 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
trust me this is not a smart remark either but you don't know as much about oil as you think.
another thing to consider is that VERY, VERY few engine problems can be attributed to oil. more often than not it's oil delivery problems and/or improper assembly craftsmanship.
last i researched shell still had a decent amount of ZDDP in it.
oil quality would be low on my list of factors when diagnosing a failure
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: jamesc] #1666609
09/03/14 10:31 PM
09/03/14 10:31 PM
Q
Quicktree Offline
Quicktree  Offline
Q
just something else to blame a failure on. the cheapest modern day no name oil on the market will get the job done.
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: Quicktree] #1666610
09/03/14 10:39 PM
09/03/14 10:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If it has a SAE standard to it... no problem and all
the stuff I buy does have the SAE standard on it
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: Quicktree] #1666611
09/04/14 12:39 AM
09/04/14 12:39 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Only as long as the engine is designed around the oil.
Chevy put ti rods and ultra light pistons in their modern LS7 small block because the Mobil 1 5w30 they "swear by" as their factory fill oil couldn't maintain adequate film strength in durability testing with more normal weight parts... and that's only a 500 HP (SAE net) hydraulic roller street engine.
And how quickly people seem to forget all the flat-tappet cam failures attributed to the major reduction in zinc, etc., due to the EPA mandating the reduction to save the cat converters.
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: BradH] #1666612
09/04/14 12:59 AM
09/04/14 12:59 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Well I had 2 1996 vetts both 6sp with the LT4 one with minor upgrades and the other one was pushing 490hp with heavy ol steel rods and regular ol pistons and I beat the he!! out of both of them for years and the Mobil 1 did just fine.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: dusturbd340W5] #1666613
09/04/14 01:21 AM
09/04/14 01:21 AM
BradH Offline OP
BradH  Offline OP
Mobil 1's formulation has changed significantly over the last 15+ years. The stuff from back then was better suited to that type of application than what's on the parts stores shelves today.
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: BradH] #1666614
09/04/14 01:38 AM
09/04/14 01:38 AM
BradH Offline OP
BradH  Offline OP
Ya' know, I took 3 months off from posting here and this is my first thread since May.
I decide to post this oil info from the maker of $1500+ roller lifters and half of you just want to get into a pi$$in' contest over how it's not good advice and how running Wal-Mart brand is all you need.
This place makes no sense...
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: Thumperdart] #1666615
09/04/14 01:42 AM
09/04/14 01:42 AM
BradH Offline OP
BradH  Offline OP
Welcome back Brad!
Brad's gone... I killed that a$$hole for taking too long to get his junk back together. - Lars Peart (a.k.a. Drummer 1-3/4)
Guess I`m not the only drummer who`s "Bumped his head".........
I think I need a bigger bump to my head to make me forget this forum even exists.
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: BradH] #1666616
09/04/14 01:50 AM
09/04/14 01:50 AM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
As of a couple years ago, the Mobil 1 4T bike oil was the same formulation as their 1990's "NASCAR" oil. It had the right additive package.
The 15W-50 Mobil 1 is also still suitable. It has elevated levels of ZDDP compared to other grades of Mobil 1.
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: BradH] #1666617
09/04/14 08:23 AM
09/04/14 08:23 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Welcome back Brad!
why because people tell you what you don't wont to hear?
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: Quicktree] #1666618
09/04/14 09:02 AM
09/04/14 09:02 AM
maryland
74yellowduster Offline
maryland
zinc schmink
jesel probably cut some kind of marketing deal with joe gibbs or something
build it right everything checked dont just slap stuff together they are fine on most any oil that is changed regularly
you could run 1000000000 ppm zddp but if you build the engine without attention to detail it's not gonna last
here is a good read on oils this guy actually is an engineer that has TESTED and documented over 100 different motor oils how they compare for overall wear protection. the rankings start about 1/2 down the page
http://540ratblog.wordpress.com/2013/06/20/motor-oil-wear-test-ranking/
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: BradH] #1666619
09/04/14 10:51 AM
09/04/14 10:51 AM
Kissimmee Fl.
Kissimmee Fl.
I don't doubt that but I didn't buy either of them until 2004 they both had less than 5k on them when I got them
and I not in a pissin match just stating facts.
is less zinc a good thing NO but as stated build the motor correctly and change oil like you should and any SAE oil will serve you well.
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: dusturbd340W5] #1666620
09/04/14 10:52 AM
09/04/14 10:52 AM
Kissimmee Fl.
Kissimmee Fl.
Oh and all the lifter failures years ago was more about a huge batch of lifters that had been machined wrong and was let out in the market place than an oil problem.
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: Quicktree] #1666621
09/04/14 11:08 AM
09/04/14 11:08 AM
BradH Offline OP
BradH  Offline OP
Welcome back Brad!
Not hardly. It's just been a reminder about how this forum has de-evolved into much less tech and much more opinion (rather than fact- or data-based) bantering and ego thumping.
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: 74yellowduster] #1666622
09/04/14 11:16 AM
09/04/14 11:16 AM
BradH Offline OP
BradH  Offline OP
Yes, the (in)famous 540Rat... whose methodology and interpretation of his data has been run though the wringer by smarter people than us over on SpeedTalk and considered "questionable" at best and downright bogus at worst.
He would never even post pictures of his test machine to dispute the claims that it was nothing more than a modern-day "one armed bandit" as used by shyster oil additive companies in the past.
I don't drink his oil testing Kool-Aid.
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: dusturbd340W5] #1666623
09/04/14 11:21 AM
09/04/14 11:21 AM
BradH Offline OP
BradH  Offline OP
That may have been PART of the issue (there was an influx of improperly machined offshore-sourced lifters as I'd been told from sources in the industry), but was certainly not the reason for "all the lifter failures years ago..."
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: BradH] #1666624
09/04/14 11:25 AM
09/04/14 11:25 AM
BradH Offline OP
BradH  Offline OP
Sorry for apparently wasting everyone's time on here. This forum simply isn't what it used to be from an engine tech perspective.
I'll be far more selective in what I bother to post or respond to in the future and will leave the threads to others.
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: BradH] #1666625
09/04/14 01:44 PM
09/04/14 01:44 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
We buy the very best Hi $$$ parts find the Best Engine Hi $$$ Builders/Machinist to machine/build the engines to make sure everything is right.And after spending all of that $$$ we say if we use the very best parts and use the very best engine builders/machinist and we are 100% sure its built right,there is no reason to have to use the Hi $$$ oil the cheap stuff is just fine! I'm Guilty as anyone else on here of going overboard on engine builds and admit I will put my engine in the back of the truck and take it to the best people I can find matters not what they charge or how far I have to travel,but before I bring my engine back I ask these Hi $$$ engine Builders/Machinist what oil should I run and they all tell me use Off Road Race Oil Only if I want my engines to last.Wasting a few $$$ on oil is the least of my worries.
I use Lucas 50 weigh Off Road Racing oil,they keep it in stock at Advance here for all the round track racers but not on the selves you have to ask for it.I'm the one that talked the manager into stocking the Lucas oil along with help from all the round trackers.There is a lot more round track racers than Drag Racers around here and they change oil every week.
PS Them Hi $$$ engine builders tell me that 80-90% of engine failure now days is due to using the wrong motor oil.people just refuse to spend the extra $$$ and time to get it!
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: BradH] #1666626
09/04/14 01:49 PM
09/04/14 01:49 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Only oil mandated for use in gasoline passenger cars and trucks were required to lower ZDDP content. Your diesel and motorcycle and "off road/racing" oils are exempt from this. That is why Rotella T still ahs the zddp in it as it is a diesel oil. Also the information about content levels is available from the SAE on thier website.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: MRMOPAR622] #1666627
09/04/14 01:51 PM
09/04/14 01:51 PM
slammedR/T Offline
slammedR/T  Offline
I like that Lucas 50 weight race oil, buddy of mine runs it in his darg truck S10. It is just so hard to get it unless you order it online.
racemagnum
Page 2 of 3 1 2 3
