Re: Simulated Vinyl Top? Paint...Etc [Re: AlexP] #1666581
09/03/14 12:41 PM
09/03/14 12:41 PM
SE PA
Yellow Fever Offline
SE PA
Then use black primer.
Re: Simulated Vinyl Top? Paint...Etc [Re: AlexP] #1666582
09/03/14 01:16 PM
09/03/14 01:16 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
I don't think I'm going back with the vinyl. I'd like to put the steel hood back on and go turbine bronze metallic over everything.
Gotcha. Then talk to the paint jobber and see what's available. There has to be something in a matte finish that is cost effective. You really don't want a primer as you don't get the UV protection. It will chalk up fast in the sun.
Re: Simulated Vinyl Top? Paint...Etc [Re: Aero426] #1666583
09/03/14 03:22 PM
09/03/14 03:22 PM
PA
HuntinCuda Offline
HuntinCuda  Offline
PA
Can't believe plastidip didn't get more votes, that would be perfect. Has the heavier matte look even with a little texture and when you don't want it any longer it peels right off. It's actually made to be removed when you're ready. I've seen wheels, badges, grills..just about everything done in that stuff.
Re: Simulated Vinyl Top? Paint...Etc [Re: HuntinCuda] #1666584
09/03/14 04:00 PM
09/03/14 04:00 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
That could work. Probably doesn't have much UV protection. But for the short term...
How many cans would it take to do a top, and is it too large a surface area to get it to spray out nice?
Re: Simulated Vinyl Top? Paint...Etc [Re: Aero426] #1666585
09/04/14 12:02 PM
09/04/14 12:02 PM
PA
HuntinCuda Offline
HuntinCuda  Offline
PA
I don't think you'd have an issue at all getting it to spray nice. People have done entire cars. They also make a spray for after you dip for UV protection and added scratch resistance. This stuff is almost made for what you are looking to do. I put a link below to check out their site. It's cheap too. You can get it at lowes for like 9 bucks a can and I would think 3 or 4 cans tops would do it.
https://www.dipyourcar.com/home.php?gclid=CNHukLDcx8ACFa_m7AodbysAUw
Re: Simulated Vinyl Top? Paint...Etc [Re: HuntinCuda] #1666586
09/05/14 11:40 AM
09/05/14 11:40 AM
Delaware
GeorgeH Offline
GeorgeH  Offline
Delaware
3M chip gaurd/ rocker panel spay(there's 2 different textures available)and a few black spray bombs. But, I'm with the once and done theory on this as the factory leaded seams are not usually 100% to look nice painted without additional bodywork.
Re: Simulated Vinyl Top? Paint...Etc [Re: GeorgeH] #1666587
09/05/14 12:48 PM
09/05/14 12:48 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Carwrap vinyl with vinyltop look.
