Re: best Heads for a Stock 360
[Re: MrFuryMan]
#1666085
09/01/14 11:58 AM
09/01/14 11:58 AM
RapidRobert
The early 70's "915" heads are slightly better than any of the open chambered iron heads but would not be worth seeking out only that if they were on hand and in good shape you would want to use them. There is a closed chambered iron head but I cant think of the number right offhand. If you can port I would find Steve Dulcich's excellent porting articles for stock iron open chambered heads & he got killer flow. You mentioned stock rebuild and what is your CR (OE actual measured SCR might be in the 7's). How far down are the pistons? That is what is going to hinder you the most. I would port the hell out of your current heads and call Dave or Kevin at Hughes for a cam to build some compression
[Re: MrFuryMan]
#1666086
09/01/14 09:05 PM
09/01/14 09:05 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
302's are the closed chamber LA heads, but they are 318 port and valves. Found on the 85+ 318 roller engines.
You might want to consider a magnum head swap. Hughes should be able to set you up with springs that will work with that came for not too much money. You would also need an intake like the crosswind, FWIW I've always heard the Torker you are running is a horrible intake so you might be wanting to change that anyway.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: Michael Ecks]
#1666087
09/01/14 10:21 PM
09/01/14 10:21 PM
RapidRobert
Michael is dead on, I forgot about mag heads & yes I had heard that the original torker (at least the big block one) has bad mixture distribution issues. Worked new EQ's would be the way to go for mag heads
[Re: RapidRobert]
#1666088
09/01/14 11:06 PM
09/01/14 11:06 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Edelbrock magnum small block heads. Closed chamber to bump compression, and flow enough to support 450 crank HP easy.
**Photobucket sucks**
[Re: RapidRobert]
#1666089
09/01/14 11:11 PM
09/01/14 11:11 PM
Posts: 15,487 Florida
scratchnfotraction
I would freshen up the 360 heads you got and call Hughes for a 340/360 whiplash cam. (valve job running 1.88 or 2.02 intake valves.) it is made to work with the low comp ratio on the stock smogger small block engines. I love my 318 roller whiplash with the Holley street dominator/Holley 6210-650cfm spredbore double pumper. I am going with this 340/360 cam with the 89 roller cam 360 headed 318 police engine I am working on. if you go with the #302 small port closed chamber head 1.78/1.50 valves up the valve size and port them.. they raise the comp and make some torque on a 360 but are choking it above 4000 rpm untouched-ported can get 350+ HP. unless adding pistions/comp ratio the alum heads are not a good upgrade for a lopo stocker 360. IMHO. I would ditch the torker intake looking for a LD340/holley strip dominator/edelbrock RPM air-gap.
[Re: kork340]
#1666092
09/02/14 02:08 AM
09/02/14 02:08 AM
RapidRobert
& the 308's are far better than the 915's which I erroneously stated earlier that the 915's were the best (open chambered iron heads)
