Re: Boring a 273 Block to a 340 Block [Re: barracuda man] #1666022
09/01/14 09:55 PM
09/01/14 09:55 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
I have 2 of these 273ci engines both are 1967.one being the 235hp version the other 180hp.What are they good for other than a boat anchor.
The 235 hp 273 is no 340, but by NO MEANS a slouch. It's 10.5 to 1 comp ratio and solid lifter setup is a good foundation to start with. Makes for a good rod engine or a screaming drag powerplant in a 2000lb (or less)
chassis. It's a matter of personal choice on your buildups or motors. But there are two ways to go with a motor - either increase displacement or/ and breathing ability at any rpm and lighten the load to accelerate quicker. Tne
180 hp version is a decent powerplant for utility
usage with great mileage manners to boot.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Boring a 273 Block to a 340 Block [Re: HYPER8oSoNic] #1666023
09/02/14 09:12 PM
09/02/14 09:12 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Put a cam only 5.7 hemi in it. And sub 100k long block, with a car 5.7 intake, springs and a cam will put down about 330rwhp. You'll make more power than most combos with something simple. A little less than 400 crank with room to grow.
If you find a complete shortblock, you can have it running and in the car for $5-8k depending on how thrifty you are.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Boring a 273 Block to a 340 Block [Re: AlexP] #1666024
09/03/14 02:55 PM
09/03/14 02:55 PM
dogdays Offline
dogdays  Offline
The Hemi is the cool choice.
Sorry to pee in others' Cheerios, but there's nothing a 273 can do that a 318 can't do better.
318 advantages: 750 more cc, or 45 cubic inches, same stroke, same rotating mass, larger bore makes the heads flow better. Plus they're the same weight, and you can get them for about free. I have been given three 318s in the past few years, and missed a fourth for $50 complete, due to a flaky seller.
I would like to see a 273 stroker but it'd have to use another engine's pistons to be worthwhile, meaning no $600 custom forgings.
R.
Re: Boring a 273 Block to a 340 Block [Re: dogdays] #1666025
09/03/14 08:35 PM
09/03/14 08:35 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I used to think that all the 273's had forged cranks & adjustable rockers so I kept one out of a 67 barracuda for years when I was scraping decided to pull the crank which ended up being cast & it had a hydraulic cam w/non-adjustables
Re: Boring a 273 Block to a 340 Block [Re: AlexP] #1666026
09/04/14 12:43 AM
09/04/14 12:43 AM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
We'll see... I've always been fond of the GenIII's but it's awfully difficult and tight to wedge it in there with PS and a stock-style suspension.
