4-wheel disk brake manual master #166554
12/12/08 01:37 PM
12/12/08 01:37 PM
Anonymous OP
Anonymous OP
So, where can I get one?
Preferably, something I can get from the corner parts shop.
69 barracuda, '73 front dart discs, '84 caddy seville rear discs
Re: 4-wheel disk brake manual master #166555
12/12/08 02:27 PM
12/12/08 02:27 PM
moparAL Offline
moparAL  Offline
Dr. Diff was working on one don't know if it ever came out???
Re: 4-wheel disk brake manual master #166556
12/12/08 03:10 PM
12/12/08 03:10 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I used a manual master cylinder from an early 80s truck. It's WAY too big for the M-body calipers in front and Caddy rear calipers.
Hard braking usually required firm application of both size 15 feets and 225 lbs of my chunky butt hovering above the seat.
I put the monster AMG calipers on the front and now the pedal feels just right.
- Stu Harmon
Re: 4-wheel disk brake manual master #166557
12/12/08 03:31 PM
12/12/08 03:31 PM
AndyF Online content
AndyF  Online Content
I don't think you'll ever find a master cylinder that will work with A body calipers up front and Caddy calipers in the rear. Those two items are so mis-matched that you can't solve it with a single MC. You would most likely need dual masters to make that combination work with the MC feeding the rears having a much smaller piston.
Re: 4-wheel disk brake manual master [Re: AndyF] #166558
12/12/08 08:11 PM
12/12/08 08:11 PM
port alberni CAN.
BLACKFISH Offline
BLACKFISH  Offline
port alberni CAN.
I use an early 80's power brake master with and adjustable valve for the back. Stock a-body up front and caddy in the back. Stops great. It's the aluminum bodied master with plastic resivoirs.
RAYBESTOS PT#MC39178
Re: 4-wheel disk brake manual master [Re: moparAL] #166559
12/13/08 11:04 AM
12/13/08 11:04 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
The master cylinder Dr Diff recommended and sold me for my 1968 A-body is cast iron unit that has a 15/16th's bore and works perfectly with the 11 3/4" Unicast fronts with hDr Diff's 2006 Mustang Cobra "R" rear disc kit.
It's really an incredibly balanced combination for a low-cost, non-power, heavy-duty street system. I highly recommend it and the kind Doctor!
Re: 4-wheel disk brake manual master [Re: AndyF] #166560
12/16/08 05:15 PM
12/16/08 05:15 PM
KS
MoparKansas Offline
MoparKansas  Offline
KS
Andy -
Would an adjustable proportioning valve solve the problem with the rear brakes? I bought one of the TSM kits a long time ago and planned on using it and the 11 3/4 Cordoba brakes (from your stock of rotor club for men rotors ) on the front of my '73 Challenger. Seemed like it would be good upgrade?
Can you expand on why one of the truck masters won't work? I'm a little too far into polishing one of these master cylinders to believe that it wont work. But I would rather be safe than sorry...
