AAR, AUTO, Torque Converter Help Needed #1665005
08/28/14 11:30 PM
08/28/14 11:30 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
So I send my trans off to the shop for rebuild along with the converter. Stress the importance that I get my original pieces back and told "no issue, the torque converter rebuild shop doesn't stock your converter AND I'll request they rebuild yours"
I pick it up today and I notice the converter they provided is missing the drain plug (not mine). The're trying to make it right but I have little faith they will locate my original converter (and hardware, as I recall the plug had markings). He claims if they can't find mine they will find a replacement. So here are my questions
Prior to turn in I wasn't able to find any PN's on my converter, any idea how one would be able to tell a correct one from an incorrect?
Parts manual doesn't show a converter for a 340 3-2bbl, only a 440 3-2bbl (3410839)
Would it have been the same as a 340 4bbl? (2801764), this PN also appears on 318 and 383 models??
Stall speeds as provided in the service manual doesn't address 340 2-6bbl converters at all, so whats the stall for a 340 3-2bbl, same as 340 4bbl (2250-2450)?
Tech service bulletin for AAR's doesn't address this topic either
So what am I suppose to do at this point?????
Thanks for the help
Re: AAR, AUTO, Torque Converter Help Needed [Re: AAR#2] #1665006
08/29/14 01:42 AM
08/29/14 01:42 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
find out where they sent it to and go look for it..most likely on top of the pile of old ones..
Re: AAR, AUTO, Torque Converter Help Needed [Re: AARCONV] #1665007
08/29/14 02:01 AM
08/29/14 02:01 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Thats actually a good thought, its a local place I'm sure. I'll try calling to get the information tomorrow.
Re: AAR, AUTO, Torque Converter Help Needed [Re: AAR#2] #1665008
08/29/14 11:06 AM
08/29/14 11:06 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
So if I understand this correctly, the same Torque Converter (TC) PN was used on a 318, 340, and 383 4bbl, the stall speed being dictated by the engine torque when applied to the same TC.
So now what remains unknown is if there was any difference between a TC on a 3-2bbl 340 and a 340 4bbl car.
Since the trans ID number (3410969) were all used on 340 engines with 2-3bbl and 4bbl combinations, it seems reasonable the torque converters were identical as well.
I'm still hopeful someone has information to validate what TC went in the AAR's & T/A's, but thought I'd pass along my findings/thoughts
Re: AAR, AUTO, Torque Converter Help Needed [Re: AAR#2] #1665009
08/29/14 11:46 PM
08/29/14 11:46 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Update - Original located
Re: AAR, AUTO, Torque Converter Help Needed [Re: AAR#2] #1665010
08/30/14 11:04 AM
08/30/14 11:04 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Glad to hear that you tracked down tour original TC.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
