8 3/4 backing plate bolts #1664507
08/27/14 11:05 PM
08/27/14 11:05 PM
Fischer, TX
dodgepu360 Offline OP
Fischer, TX
Where can I get new bolts that go in the flange on the end of the axle that hold on the backing plate and bearing adjuster?
The ones on my RR are slightly bent and the backing plate and adjuster don't slide on easy, I had to fight them off.
I have shearched google and didn't find anything.
Thanks for the help.
Re: 8 3/4 backing plate bolts [Re: dodgepu360] #1664508
08/27/14 11:25 PM
08/27/14 11:25 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Here you go......
amk products
Re: 8 3/4 backing plate bolts [Re: ratroaster] #1664509
08/27/14 11:27 PM
08/27/14 11:27 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Or here.....
megaparts
Re: 8 3/4 backing plate bolts [Re: ratroaster] #1664510
08/27/14 11:42 PM
08/27/14 11:42 PM
BDW Offline
BDW  Offline
Re: 8 3/4 backing plate bolts [Re: ratroaster] #1664511
08/27/14 11:43 PM
08/27/14 11:43 PM
Fischer, TX
Fischer, TX
Thanks I got them ordered
Re: 8 3/4 backing plate bolts [Re: ratroaster] #1664512
08/27/14 11:45 PM
08/27/14 11:45 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Re: 8 3/4 backing plate bolts [Re: DoctorDiff] #1664513
08/28/14 01:23 AM
08/28/14 01:23 AM
I'd get em from Doc or might be able to use regular bolts & iirc you have to grind part of the head for em to fit flush behind the flange (dont quote me on that) if you are going back together ASAP & need em yesterday & I dont see a problem with coarse thread bolts.
