A - 833 Clutch and transmission install #166284
12/11/08 11:27 PM
12/11/08 11:27 PM
Alberta Canada
Demoman Offline OP
Demoman  Offline OP
Alberta Canada
Hey guys i am 23 years old and restoring my first car a 69 coronet and converted it from auto to manual, I got the pedals and tranny tunnel in and the tranny and shifter all to where it needs to be.. this is my first manual tranny install.. My 440 has the pilot bushing already installed.. I bought a centerforce duel friction clutch.. I have a fly wheel that came with the tranny.. I do not have a throw out bearing.. or a z bar and clutch linkage.. Does anyone have a good diagram on how to put it all together..?
thanks
Re: A - 833 Clutch and transmission install [Re: Demoman] #166285
12/11/08 11:41 PM
12/11/08 11:41 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Dig around on this site. http://www.brewersperformance.com/default.htm
You can also do a search in the archives.
Re: A - 833 Clutch and transmission install [Re: Demoman] #166286
12/12/08 12:20 PM
12/12/08 12:20 PM
Saskatoon Sk, Canada
Mark340A66 Offline
mopar addict
Mark340A66  Offline
mopar addict
thanks
Are you using a factory bellhousing? IMHO much easer to sort out linkage than if you have a scettershield. It can;t be installed if you don't have a throwout bearing.I'd use a CF bearing. FSM is the best if you are going factory parts. The CF D-F is a great clutch, I had one in my 70 340 Challenger. You will have to pull out the Over-Center spring. it's too much for a diaphragm clutch.
Good Luck.
Mopar or No Car: Sold Nov/06 1970 Challenger 340 4bbl (A66 code), A833 4 speed, 3.23 SureGrip all numbers match. 03 Dodge SX 2.0 R/T 2.0L HO(CDN Neon R/T) Black w/Grey Leather, Sunroof
Re: A - 833 Clutch and transmission install [Re: Demoman] #166287
12/12/08 04:01 PM
12/12/08 04:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The tech archives have some good diagrams of clutch linkage:
http://www.moparts.org/Tech/Archive/clutch/13.html
