Valve spring specs with MP 296/.557" solid flat tappet?
#1661834
08/21/14 06:04 AM
08/21/14 06:04 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
I'm working on a W2 heaaded 340 that has some valvetrain problems, the valve springs were singles with a damper which kind of botheres me, so I checked the seat pressure and it was only 60 lbs. What should the seat pressure be with this cam, and what should it be over the nose?
Plynouth VIP '67 TT IC EFI
Re: Valve spring specs with MP 296/.557" solid flat tappet?
[Re: skicker]
#1661838
08/21/14 02:36 PM
08/21/14 02:36 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
what install height do you need with your w2 heads?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Cab_Burge]
#1661840
08/21/14 03:35 PM
08/21/14 03:35 PM
Posts: 861 lancaster,california
johnnycuda
I had this cam in my street/strip 340 with J heads, about 10 years ago, double with a dampener spring, were at 145 on the seat and 340 open. I want to say installed height was 1.800/1.850?..been a long time, not positive on te height.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
