Page 2 of 11 1 2 3 4 10 11
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: 72Swinger] #1661330
08/21/14 03:38 AM
08/21/14 03:38 AM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
On the wheels I would get 4 fronts and just use thin billet spacers on the rear. The ability to rotate front to back helps a ton on the pocket book.
That would be great. My only worry is how "thin" the spacer will need to be.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661331
08/21/14 05:21 AM
08/21/14 05:21 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Here is a picture of the hose routing in this recent thread. The L-bracket which retains the hose, bolts to the caliper bracket:
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=8189403&Main=8188020
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661332
08/21/14 05:26 PM
08/21/14 05:26 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
I know Dr Diff recommends the 15/16" bore but when I checked on his website a couple days ago, I think he said the MC was out of stock. I don't think I have feets' brake calculator saved to my laptop. I could probably do a quick search for it.
Feets calculator:
http://3gduster.com/brakes.html
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: DoctorDiff] #1661333
08/22/14 03:00 AM
08/22/14 03:00 AM
SoCal
SoCal
Thanks for the response and the email! I saved the picture on my laptop.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: Uhcoog1] #1661334
08/22/14 03:02 AM
08/22/14 03:02 AM
SoCal
SoCal
Feets calculator:
I was fiddling around with it last night and tonight. Seems like if I'm going to get 1000+ psi of MC pressure, I'm going to have to exert 130 lbs with my current MC as opposed to 110 lbs if I were to get the 15/16" bore. I know I'll have shorter travel with my current MC, I just don't know how much shorter.
Click on "Attachment" above for a bigger picture.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661335
08/22/14 09:58 PM
08/22/14 09:58 PM
SoCal
SoCal
Does anyone have MOOG part numbers for replaced ball joints and pitman/idler arms? I'd like to order some from rockauto today.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661336
08/22/14 10:08 PM
08/22/14 10:08 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
Assuming you have the 73+ A-body knuckles, you just want to order the parts for a '73 Dart 318
Inner Tie Rod:ES401L
Outer Tie Rod:ES401R
Left Lower Ball Joint: K783
Right Lower Ball Joint: K781
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661337
08/22/14 10:15 PM
08/22/14 10:15 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Don't forget to compare the price of them at Amazon too..with free prime shipping, it can work out cheaper than Rock at times depending on what the stuff is and where rock is shipping it from.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: OzHemi] #1661338
08/22/14 10:42 PM
08/22/14 10:42 PM
SoCal
SoCal
That's what I was just doing; however, my sister would have to order them because I don't have a prime account. They seem to be the same price but with no shipping.
So, this is what I got,
LCA Ball Joint:
Left Lower, #K7023
Right Lower, #K7021
or
Left Lower, #K787
Right Lower, #K785
I can't seem to notice a difference on these besides part number...
Idler Arm:
#K7042
Pitman Arm:
#K7074
Does anyone know if I put 1 in the quantity that 2 idler/pitman arms will show up or do I have to put 2 in the quantity?
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: goldduster318] #1661339
08/22/14 10:43 PM
08/22/14 10:43 PM
SoCal
SoCal
Doh... Totally forgot to mention I was using 73+ A-body knuckles. Thanks for catching me.
Now, the TVS comes with adjustable tie rods, does that mean I'm not going to need one of the two tie rods?
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661340
08/22/14 10:45 PM
08/22/14 10:45 PM
Lake Orion, MI
Lake Orion, MI
LCA Ball Joint:
Left Lower, #K7023
Right Lower, #K7021
or
Left Lower, #K787
Right Lower, #K785
Idler Arm:
#K7042
Pitman Arm:
#K7074
You only need 1 idler arm and 1 pitman arm per car. Pitman is on the steering box, idler is on the k-frame. You were probably thinking tie rod ends.
All parts sold individually
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: goldduster318] #1661341
08/22/14 10:47 PM
08/22/14 10:47 PM
Lake Orion, MI
Lake Orion, MI
So...In your case just so we're clear.
Pitman and Idler arm for your original application, '68 Dart
Tie rods could be for either '68 or '73, they are the same
Lower Ball joints are 73 with disk brakes.
Hope your TVS has the large ball joints for the later application.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: goldduster318] #1661342
08/22/14 11:05 PM
08/22/14 11:05 PM
SoCal
SoCal
LCA Ball Joint:
Left Lower, #K7023
Right Lower, #K7021
or
Left Lower, #K787
Right Lower, #K785
Idler Arm:
#K7042
Pitman Arm:
#K7074
Just to make sure I get this right. This is a a front end assembly out of '71 Demon I have at home... The TVS comes with adjustable tie rods, tubular UCA (for larger ball joints), and strut rods. So would I need to replace the inner and outers? What's considered the inner and outers?
Here's a link to the TVS instructions manual. If I think, what you think, the inner and outer tie rods are, I don't think I need them...
http://www.hotchkis.net/_uploaded_files/80113.pdf
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661343
08/22/14 11:08 PM
08/22/14 11:08 PM
Lake Orion, MI
Lake Orion, MI
Yeah, you got it.
So you'd only need idler and pitman arms and some lower ball joints. I forgot about the full TVS having the rod end tie rod setup. I wasn't planning on using that on my own car (buying components only)
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: goldduster318] #1661344
08/22/14 11:18 PM
08/22/14 11:18 PM
SoCal
SoCal
So final parts list:
Ball Joints: #K783 and #K781
Idler Arm: #K7042
Pitman Arm: #K7074
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661345
08/23/14 11:55 AM
08/23/14 11:55 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The tie rod assembly you have circled is made up of an inner tie rod, an adjusting sleeve, and an outer tie rod.
If you're rebuilding your front end it makes sense to replace these parts. The joints will get sloppy with wear, just like a ball joint.
- Stu Harmon
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: feets] #1661346
08/23/14 01:47 PM
08/23/14 01:47 PM
SoCal
SoCal
I figured that out when I took a look at them in the garage but the TVS comes with tie rods...
http://www.hotchkis.net/mopar_abody_adjustable_steering_rod_kit.html
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661347
08/28/14 01:57 AM
08/28/14 01:57 AM
SoCal
SoCal
Got the rest of my front end parts yesterday. I'm trying to see if I can find a friend who's free this Friday and Saturday to help me take it apart and hopefully start putting it back together, but I may end up doing it alone. For now, I'm going to be looking at some Youtube videos and my service manual.
Thursday I'll take it to the local car cruise one last time and then drive it over to the local do-it-yourself car wash and clean out as much gunk as I can from the bottom.
Then the tear down begins. I'm not going to lie, but I'm a little nervous.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661348
08/28/14 02:01 AM
08/28/14 02:01 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
The front end is easy if you have the correct suspension tools. I have the American Muscle Suspension Tool kit and its a piece of cake!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: RylisPro] #1661349
08/28/14 02:14 AM
08/28/14 02:14 AM
SoCal
SoCal
Yeah, I know I don't have the right tools. Looking at that kit, I don't know how many of those I'd need right now besides maybe the T-bar remover, LCA sleeve remover, and LCA pivot remover. I probably should order it and try to get it in soon. I think I'm going to get stuck on this portion because of lack of tools unless I can try borrowing some from a friend.
How do you remove the lock ring on the T-bars? Should I be installing new boots?
Would it be a bad idea to just remove the UCA, brake, and spindle assembly as one piece just for ease? I'm not going to be reusing any of those parts for the Dart.
I found these videos to be pretty decent refrences...
https://www.youtube.com/watch?v=-YNoYLVX7TE
https://www.youtube.com/watch?v=Lxi_bOTfrM0
https://www.youtube.com/watch?v=dZ-K6BiKido
