E85 Update
#1660474
08/18/14 03:17 AM
08/18/14 03:17 AM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
finally got time to take the Scamp for a cruise, took about ten minutes to tune the carb, The whole time idling the temp only got to 160. totally stoked on how it performed, no track test yet but took it for a 15 min drive and only got up to 175. even after making a few WOT hits. ran great and thanks to AJ Casini for doing the conversion track results next. btw driving to the track hoping to get in the 9's and drive it back
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: E85 Update
[Re: jughed]
#1660476
08/18/14 01:14 PM
08/18/14 01:14 PM
Triple Threat
Renton Washington
Glad to hear the first drive went well, I think you're really going to enjoy this switch!
Coming out saturday night?
Re: E85 Update
[Re: Stroker Scamp]
#1660477
08/18/14 06:17 PM
08/18/14 06:17 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
I have wanted to run E-85 for a while now. The only thing slowing me down is replacing my whole fuel system. I hear you have to run the right kind of hose, all the aluminum has to hard anodized. Do you have special line or will any steel braided line work? My fuel pump is a marine Mallory 140 with the return style regulator. Do I need a different pump and regulator? Any help would be greatly appreciated.
Re: E85 Update
[Re: Triple Threat]
#1660478
08/19/14 02:14 AM
08/19/14 02:14 AM
Stroker Scamp
pacific northwest
Dustin you are correct I am digging it so far, not going to make it this weekend going camping. good luck to you
Re: E85 Update
[Re: Biginchmopar]
#1660479
08/19/14 02:20 AM
08/19/14 02:20 AM
Stroker Scamp
pacific northwest
I have braided lines thru out the car, aeromotive pump and regulator, I spoke with AJ Casini (member here) he is the one who did my carb, so he said everything I had should work. Not sure on your pump it needs to flow quite a bit more than gas
Re: E85 Update
[Re: Biginchmopar]
#1660482
08/19/14 02:56 AM
08/19/14 02:56 AM
Stroker Scamp
pacific northwest
SB 408, ported eddys, 13/1 comp. roller cam I cannot buy race gas again, last time I did it was $14 a gallon It is well worth it even if you need to buy some parts to run it Go for it
Re: E85 Update
[Re: Thumperdart]
#1660486
08/20/14 03:02 AM
08/20/14 03:02 AM
Stroker Scamp
pacific northwest
yup tired of this $14 gallon stuff, will be nice to just take the car for a drive.
Re: E85 Update
[Re: ajcasini]
#1660490
08/20/14 04:25 AM
08/20/14 04:25 AM
Biginchmopar
Carson City, Nevada
With the fuel pump you want to make sure it can feed 30% more than what you would require on gas.
As far as fuel line any of the popular braided lines will work just fine. With the fuel filter you will want to run the steel mesh style 100 micron. I have seen some issues with fuel cell foam deteriorating best to remove it or at least test it with some e85 in a jar to see what the reaction is.
The only pressure regulators I have had issues with are the Barry grant 2 and 4 ports. Any diaphragm regulator with a green diaphragm will work. I have used quick fuel, aeromotive and even the cheap cast holleys with no issues.
If you have any other questions let me know.
So good to hear the carb is installed and you got her running. Let me know if you need anything else.
Thanks for the info! Looks like I better start ordering parts.
