Front disk brake conversion question #1660399
08/17/14 10:37 PM
08/17/14 10:37 PM
Logansport, Indiana
Budman Offline OP
Budman  Offline OP
Logansport, Indiana
Im wanting to buy a front disk brake conversion kit for my 67 Belvedere. Its a street driven Big Block car. Im wanting something lightweight and the best "Bang for the Buck".
All MOPARS & nothig else.
Re: Front disk brake conversion question [Re: Budman] #1660400
08/17/14 11:16 PM
08/17/14 11:16 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
contact dr diff on this site or do a search on the web for Dr. Diff. other than that there is a write up in the tech section on what to do and what to get.
Re: Front disk brake conversion question [Re: Budman] #1660401
08/17/14 11:42 PM
08/17/14 11:42 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
here are the blueprints for using factory parts.
http://www.moparaction.com/tech/archive/disc-main.html
Re: Front disk brake conversion question [Re: mikemee1331] #1660402
08/17/14 11:42 PM
08/17/14 11:42 PM
IN
ahy Offline
ahy  Offline
IN
In general, the mid to late 70's 11.75" setup is best bang for the buck. Plus replacement parts are readily available. There are lots of ways to do this and the attached "disk o tech" from MA provides a good starting point. It requires 15" minimum wheels. Master Power Brakes has smaller rotor kits that may work with 14" wheels. I understand Dr Diff is and expert in all this area.
http://www.moparaction.com/tech/archive.html
Re: Front disk brake conversion question [Re: ahy] #1660403
08/18/14 01:49 AM
08/18/14 01:49 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Lightweight means nothing OEM on it!
Re: Front disk brake conversion question [Re: RobX4406] #1660404
08/18/14 01:59 AM
08/18/14 01:59 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
...FAFO...
Re: Front disk brake conversion question [Re: skicker] #1660405
08/18/14 02:38 AM
08/18/14 02:38 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
That is pretty much the case. The factories probably figured that the extra weight penalty was worth it to maintain 100,000 mile durability.
The lightweight stuff is often drag race oriented. Those guys only have to stop once every 1/2 hour or so. A street car in bumper to bumper traffic would probably warp the lightweight rotors in short order.
Re: Front disk brake conversion question [Re: Budman] #1660406
08/18/14 10:05 AM
08/18/14 10:05 AM
Georgia
Steve Bryant Offline
Georgia
Last winter, I followed the Disc-O-Tech article to the "T" and insalled pin-type front brakes on my 70 Cuda and it was a fairly simple operation. At the time, I had 14" wheels so I went with the smaller calipers and rotors but they are easy to upgrade. I get my rotors from the local parts store and tell them its for a '74 duster.
For me, I was happier following these steps and ordering a kit plus it was a lot cheaper and it's "factory"
A couple of things I learned are the dust shield really isn't needed its probably not worth spending too many cycles getting the right shields. I also learned that you need to go ahead and spend the money on good prop/dist valves and "t"s. If you skimp on this, you may not be happy. Lastly, your local parts store may have more parts than you think so check 2-3 times and local places. For example, I bought a brake booster and (NEW) Master Cylinder at O'Reily's for less than $150 and the booster even has the Chrysler logo. Buy a new MC and not a refurb.
Since you have to buy new spindles for the conversion this is a good time to think about ride height. I like my front a tad lower than the rear so I bought a pair of dropped spindles from PST and they give me an excellent ride height without air-shocks.
The only regret I have now is staying with the rear drums. I should have swapped them out too. 4-Wheel discs have easier plumping and a more natural feel plus they don't drag on release.
Re: Front disk brake conversion question [Re: Steve Bryant] #1660407
08/18/14 02:35 PM
08/18/14 02:35 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
I think you did good keeping things simple, effective, and realistic.
Many rear disk swaps run into master cylinder and pedal effort issues/tuning. There is not much added stopping power on the street with simple disks. Especially with stock spring rates and stockish BFG T/A type tires. If you get to that point or rear drum fade on the street, your stock fronts will be fading too.
I thought disks have more drag when not applied than drums?
Re: Front disk brake conversion question [Re: autoxcuda] #1660408
08/18/14 03:13 PM
08/18/14 03:13 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..i have always questioned the hassel and expense of rear discs.
..75% of your braking is usually handled by the front brakes.
Re: Front disk brake conversion question [Re: can.al] #1660409
08/18/14 04:45 PM
08/18/14 04:45 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
Also check out kits from MBM, Speedway Motors, and Wysco Product.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: Front disk brake conversion question [Re: BradD] #1660410
08/18/14 05:20 PM
08/18/14 05:20 PM
RobX4406 Offline
RobX4406  Offline
If low cost is what you are looking for, go with a set of FMJ spindles/rotors/calipers.
The haters will be in complaining about the bogus spindle height issue in 3...2...1...
Check with 65belvjim. He had a set a couple days ago.
Re: Front disk brake conversion question [Re: RobX4406] #1660411
08/18/14 11:45 PM
08/18/14 11:45 PM
Logansport, Indiana
Budman Offline OP
Budman  Offline OP
Logansport, Indiana
WOW
Thank you everybody for all the info. Great suggestions and Im taking them all in. Im not looking for the cheapest just good set up. I would like to find a set that not as heavy as the factory stuff. Thanks for all ur suggestions. I will continue my research. All ideas and suggestions are welcome. Thanks again
Re: Front disk brake conversion question [Re: Budman] #1660412
08/19/14 01:43 AM
08/19/14 01:43 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I just did this swap in the spring on my 67 Belvedere. I used the kit from Right Stuff Detailing(lines and all). Simple kit, everything was included. No major bending of lines.
Ok
Re: Front disk brake conversion question [Re: cudatom] #1660413
08/19/14 02:04 AM
08/19/14 02:04 AM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
on e-bay, look up scarebird, he sells parts that bolt to your existing spindles, I think he uses GM rotors and calipers, the good news is anybody would carry replacement parts for them.
Joey
Re: Front disk brake conversion question [Re: autoxcuda] #1660414
08/19/14 12:16 PM
08/19/14 12:16 PM
Yes they do & some more than others (of the same type of caliper)
Re: Front disk brake conversion question [Re: Budman] #1660415
08/19/14 12:28 PM
08/19/14 12:28 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
I bought spindles off a 73 dart...the rest off napa..(bearings,pads,rotors,install kit,etc) and cost just under 400.00
67 R/T...stops.....excellent.....but if you have $$$$$$$ to burn....get a 800 + kit
Re: Front disk brake conversion question [Re: terzmo] #1660416
08/19/14 06:52 PM
08/19/14 06:52 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
I'm using the whole FMJ disc brake setup..stops straight hard..and cheap!!
Re: Front disk brake conversion question [Re: dynamite] #1660417
08/19/14 08:05 PM
08/19/14 08:05 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
all right, i'll bite. what is FMJ disc brakes. I can't find anything!
Re: Front disk brake conversion question [Re: mikemee1331] #1660418
08/19/14 09:42 PM
08/19/14 09:42 PM
Eastern Shore of Maryland
N
nasty68 Offline
nasty68  Offline
N
F,M,J are brakes that were on the dodge aspen and plymouth volare and like models. I run them on my dart.
68 dart, 383, 727
2013 Jeep JKU Sahara
