anybody using pro-comp rockers on victor heads #1660308
08/17/14 07:59 PM
08/17/14 07:59 PM
illinois
rbkt65 Offline OP
rbkt65  Offline OP
illinois
I bought victor max wedge heads for my 540 and see that there are several offsets offered-Hughes .640,procomp .610,the source .650. pro comp is cheapest but at what cost? any feed back is greatly appreciated. also are any of these going to have concern with stock valve covers? thanks in advance rick
Re: anybody using pro-comp rockers on victor heads [Re: rbkt65] #1660309
08/17/14 10:14 PM
08/17/14 10:14 PM
tboomer Offline
tboomer  Offline
Rick...I have the Hughes on mine and am happy with them.
Re: anybody using pro-comp rockers on victor heads [Re: tboomer] #1660310
08/18/14 12:10 AM
08/18/14 12:10 AM
illinois
rbkt65 Offline OP
rbkt65  Offline OP
illinois
thanks-do you have stock height v/covers or something else? thanks again
Re: anybody using pro-comp rockers on victor heads [Re: rbkt65] #1660311
08/18/14 12:53 AM
08/18/14 12:53 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
I run Harland Sharps on mine. They are very close to the valve cover rail on the pushrod side. I couldn't use a moroso valve cover (similar to stock). Ended up using procomp fabricated aluminum covers and modified the mounting face. Now I can drop covers straight down over the studs without issue. I use felpro cork gaskets with no sealer and No leaks. Also I believe the source rockers are a dead copy (dimensionally) of the Sharps. I know the beairngs are. HS sold a buddy a set of their roller beaings for their rockers and pressed them in to his source rockers and workin good.
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
