six shooter set-up #1660013
08/17/14 01:43 AM
08/17/14 01:43 AM
yarnell,az
mopacltd Offline OP
mopacltd  Offline OP
yarnell,az
Has anyone ever used the Barry Grant six shooter mopar carbs?
Re: six shooter set-up [Re: mopacltd] #1660014
08/17/14 10:52 AM
08/17/14 10:52 AM
P
Porter67 Offline
Porter67  Offline
P
If your really looking for real world testing and flow numbers and back to back vs the 2300s.
Patrick I think is a member here and is in Sweden. He is a very nice gentleman and really likes to discuss his works.
I don't think he would mind I posted his email. Last I heard he had the BG carbs on and was doing pretty well with them with a few mods on a 500 inch or so stroker.
mr440mopar@hotmail.com
Re: six shooter set-up [Re: Porter67] #1660015
08/17/14 01:44 PM
08/17/14 01:44 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
Thanks for those kind words Porter =) Yes im useing them on a 500+ stroker and i realy like them ! Many will say they flow low numbers but i did the flow test on them and if you put al 3 carbs together the BG´s will flow more than the stock Holley´s and one more benefit is the restriction that the center carb is on a bb is more or less gone whit the BG setup as al 3 carbs are equal !
Re: six shooter set-up [Re: Mopar Guy] #1660016
08/17/14 07:37 PM
08/17/14 07:37 PM
yarnell,az
mopacltd Offline OP
mopacltd  Offline OP
yarnell,az
Know of any for sale?
Re: six shooter set-up [Re: mopacltd] #1660017
08/17/14 10:24 PM
08/17/14 10:24 PM
Tehachapi, Ca.
Mtn Thunder Offline
Mtn Thunder  Offline
Tehachapi, Ca.
I have a set that are on a small block. I am taking the set up to Fall Fling to sell. If you are interested, PM me. Mike
Re: six shooter set-up [Re: Mtn Thunder] #1660018
08/18/14 12:24 AM
08/18/14 12:24 AM
yarnell,az
mopacltd Offline OP
mopacltd  Offline OP
yarnell,az
PM sent Thunder.
Re: six shooter set-up [Re: mopacltd] #1660019
08/18/14 05:58 AM
08/18/14 05:58 AM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
One thing i recomend you to do is take them apart and check them out ! on my outboard carbs bodys they had take of to mutch on the metering block surface so the the ventilation hole that runs down
to the bowl from the top of the body would have leakt out fuel so adress that if the ones you find are the same but other then that these carbs are great and the anular boosters were a good thing to.
The fuel line that came whit the carbs whas nothing i whas impesst about so to avoid a fire in the engine bay i whent whit real banjo´s !
Just send me a email if you have more you whant to know !
Re: six shooter set-up [Re: Mopar Guy] #1660020
08/18/14 12:42 PM
08/18/14 12:42 PM
yarnell,az
mopacltd Offline OP
mopacltd  Offline OP
yarnell,az
Good information Mopar Guy. Thanks
