70-74 cuda doors #1659961
08/17/14 12:52 AM
08/17/14 12:52 AM
B.C.
mk_ Offline OP
mk_  Offline OP
B.C.
Need to replace a door for my 70 cuda…..and would like to know if all 70-74 door shells are the same.
Are the side view mirrors in the same place or any other variations on the inner structure?
Re: 70-74 cuda doors [Re: mk_] #1659962
08/17/14 01:07 AM
08/17/14 01:07 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
'70 cat whiskers attach differently than '71-'74
'70-'71 side view mirrors have a different screw spacing than '72-'74
Re: 70-74 cuda doors [Re: 6bblgt] #1659963
08/17/14 02:06 AM
08/17/14 02:06 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
70 E racing mirror spacing all by itself, quite sure 71-74 rallye mirror are all the same spacing on E-body.
70 E cat wiskers clip on, 71-74 E screw on
Re: 70-74 cuda doors [Re: 6bblgt] #1659964
08/17/14 02:07 AM
08/17/14 02:07 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
71-4 mirrors are the "larger" spaced bases, only the 70 mirror is the short spaced screw base, 70 is the only year for the racing mirrors when equipped, 71-4 are considered the Rallye mirror
Re: 70-74 cuda doors [Re: DAYCLONA] #1659965
08/17/14 02:31 PM
08/17/14 02:31 PM
B.C.
mk_ Offline OP
mk_  Offline OP
B.C.
Great info…..thanks!
Re: 70-74 cuda doors [Re: mk_] #1659966
08/20/14 12:38 AM
08/20/14 12:38 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
dont forget the door lock itself..70 needs the key to lock it from the outside..71-up you just push down on the lock handle and close the door like a modern car
