brake pedal stays down
#1659741
08/16/14 05:01 PM
08/16/14 05:01 PM
Posts: 433 Wausau Wisconsin USA North Ame...
radiatorman
Hi Guys, The last bug to work out before I can drive the blue Challenger is the brake pedal. It has power disc and when you apply the brakes then let off, the pedal stays down and the brakes are on(obviously). And body know a fix for this? I did adjust the push rod and that didn't help but now that is at least adjusted right. Thanks, Bob
Re: brake pedal stays down
[Re: radiatorman]
#1659742
08/16/14 05:53 PM
08/16/14 05:53 PM
Posts: 26,000 Rio Linda, CA
John_Kunkel
Rio Linda, CA
What's the history of the booster? Internal failure is the most likely cause.
Disconnect the vacuum hose, pump the pedal until the booster vacuum reserve is depleted and see if it does the same thing.
[Re: radiatorman]
#1659749
08/19/14 01:36 PM
08/19/14 01:36 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
Had the same problem with a car that the previous owner installed a Jegs power brake conversion on. Went through everything, talked to the tech guys at the manufacturer tried everything. Finally went down to the hardware store and bought a small spring. Attached it to the pedal and then under the dash with tension. No more problem. Didn't want to do it but after trying everything else it worked.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: jt4406]
#1659751
08/19/14 05:51 PM
08/19/14 05:51 PM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
This may not be your problem, but I have seen it cause the same symptoms. Check that the bolt that holds the pushrod to the pedal is not binding on the pushrod. Since the pedal swings, it has to be able to swivel around the bolt that attaches it to the pushrod. Just my Jess
Not sure on your car, my B body has plastic bushings that were stuck to the bolt on my pedal.. Got them out, hard old grease, ran a small wheel cylinder hone throught it, reinstalled bushings w/silicone grease..
[Re: radiatorman]
#1659753
08/22/14 02:49 PM
08/22/14 02:49 PM
John_Kunkel
Rio Linda, CA
Please report back if that fixes the problem.
