Re: Milodon S/S drag link through center oil pan issues [Re: Leigh] #1659471
08/16/14 11:51 AM
08/16/14 11:51 AM
Lebanon,IN
mr2performance Offline
Lebanon,IN
Send it over. I'll do it. Mike
MR2PERFORMANCE RACE CARS 765 483 9371
Re: Milodon S/S drag link through center oil pan issues [Re: mr2performance] #1659472
08/16/14 12:37 PM
08/16/14 12:37 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Thanks for the offer to help
I found a guy here local to do it, who owns a welding business.... Will pick it up today and knock it out Monday
All goes well car should be running Tuesday. Norwalk is getting close, need to sort this thing out at the track probably twice before then.
I expect some teething problems as a couple of things are probably marginal to support what I hope the car can run( mainly fuel related) won't know till I lean on it.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Milodon S/S drag link through center oil pan issues [Re: B3422W5] #1659473
08/18/14 12:33 PM
08/18/14 12:33 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Got the link modified, fits nicely through the hole now.
But I have only about 3/4 or so turning ability turning right as idler arm hits pan. Full range to the right
It is what it is I guess.
1.41 best 60 foot
6.56 at 104.17
Re: Milodon S/S drag link through center oil pan issues [Re: B3422W5] #1659474
08/18/14 04:15 PM
08/18/14 04:15 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Ya now the headers wont fit hitting the oil pan
Re: Milodon S/S drag link through center oil pan issues [Re: B3422W5] #1659475
08/18/14 08:55 PM
08/18/14 08:55 PM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
Drag link isn't able to be bolted up on my A body. Put the nut on drivers side on, and the link is about 1.5 inches to high on passengers side from being in place.... Aargg
No way to turn the drag link down that much.... And thought about cutting it on each end and welding in a straight piece to replace how the factory bar is made ..... But an outstanding welder who could do it doesn't want the liability( understand his point).... So looks like this trick pan is unusable to me for this 318 mighty mite project
Unless somebody here has an idea....
71 Duster with slant 6 K and Shumacher conversion mounts.... Can't imagine it working with V8 K and different mounts either.... But who knows [/quot
Which one do you have the square one or the round one ???
Re: Milodon S/S drag link through center oil pan issues [Re: RAY1969CARS] #1659476
08/18/14 09:16 PM
08/18/14 09:16 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Square one
1.41 best 60 foot
6.56 at 104.17
Re: Milodon S/S drag link through center oil pan issues [Re: B3422W5] #1659477
08/18/14 09:18 PM
08/18/14 09:18 PM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
Square one
Re: Milodon S/S drag link through center oil pan issues [Re: RAY1969CARS] #1659478
08/18/14 11:17 PM
08/18/14 11:17 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Yep that's it.
Nice pan, but if using it with stock suspension and store bought headers....... Wear a metal hat to protect pulling your hair out
1.41 best 60 foot
6.56 at 104.17
Re: Milodon S/S drag link through center oil pan issues [Re: B3422W5] #1659479
08/19/14 02:54 AM
08/19/14 02:54 AM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
Yep that's it.
Re: Milodon S/S drag link through center oil pan issues [Re: RAY1969CARS] #1659480
08/19/14 03:02 AM
08/19/14 03:02 AM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
Yep that's it.
Hooker SuperCom's fit pretty nice
