Re: Milodon S/S drag link through center oil pan issues
[Re: Leigh]
#1659471
08/16/14 11:51 AM
08/16/14 11:51 AM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
Send it over. I'll do it. Mike
MR2PERFORMANCE RACE CARS
765 483 9371
[Re: mr2performance]
#1659472
08/16/14 12:37 PM
08/16/14 12:37 PM
Posts: 11,719 Portage,michigan
B3422W5
Portage,michigan
Thanks for the offer to help I found a guy here local to do it, who owns a welding business.... Will pick it up today and knock it out Monday All goes well car should be running Tuesday. Norwalk is getting close, need to sort this thing out at the track probably twice before then. I expect some teething problems as a couple of things are probably marginal to support what I hope the car can run( mainly fuel related) won't know till I lean on it.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#1659473
08/18/14 12:33 PM
08/18/14 12:33 PM
B3422W5
Portage,michigan
Got the link modified, fits nicely through the hole now. But I have only about 3/4 or so turning ability turning right as idler arm hits pan. Full range to the right It is what it is I guess.
[Re: B3422W5]
#1659475
08/18/14 08:55 PM
08/18/14 08:55 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
Drag link isn't able to be bolted up on my A body. Put the nut on drivers side on, and the link is about 1.5 inches to high on passengers side from being in place.... Aargg No way to turn the drag link down that much.... And thought about cutting it on each end and welding in a straight piece to replace how the factory bar is made ..... But an outstanding welder who could do it doesn't want the liability( understand his point).... So looks like this trick pan is unusable to me for this 318 mighty mite project
Unless somebody here has an idea.... 71 Duster with slant 6 K and Shumacher conversion mounts.... Can't imagine it working with V8 K and different mounts either.... But who knows [/quot
Which one do you have the square one or the round one ???
[Re: B3422W5]
#1659477
08/18/14 09:18 PM
08/18/14 09:18 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
[Re: RAY1969CARS]
#1659478
08/18/14 11:17 PM
08/18/14 11:17 PM
B3422W5
Portage,michigan
Yep that's it.
Nice pan, but if using it with stock suspension and store bought headers....... Wear a metal hat to protect pulling your hair out
[Re: B3422W5]
#1659479
08/19/14 02:54 AM
08/19/14 02:54 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
Yep that's it.
[Re: RAY1969CARS]
#1659480
08/19/14 03:02 AM
08/19/14 03:02 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
Yep that's it.
Hooker SuperCom's fit pretty nice
