Re: LA Engine Rocker Scrub
[Re: Kevins493]
#1659228
08/15/14 01:19 AM
08/15/14 01:19 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not sure why they do this but Small block Harlan Sharp rockers are made for longer valves. Custom push rods or lash caps help this situation. Small Block Mopar V8 Fits 1964-91 "LA" 273-360 Sets Part # Ratio Price S70025K 1.5:1 $774.00 S70026K 1.6:1 $853.00 Intake & Exhaust Rockers 70025-1 1.5:1 $ 37.90 70026-1 1.6:1 $ 37.90 Special Notes: * Needle bearing allow for more oil flow to the rockers. * Oil restrictors may be necessary to maintain oil pressure. * Rockers are designed for big lift cams requiring .100 to .150 taller valves. * Rocker shafts are drilled to allow for 3/8 mounting hardware. * Rocker spring clearance is limited to 1.500 if more spring clearance is required, contact our customer service department to discuss your options. http://www.harlandsharp.com/sb_mopar.htm
[Re: Kevins493]
#1659234
08/15/14 07:27 PM
08/15/14 07:27 PM
Posts: 361 Canada
onig
Canada
We used 1.6 rockers from Hughes. Excellent geometry and no issues for 3 years. These are also installed on RHS heads. But glad you have it sorted out with the lash caps.
69 Dart
[Re: Kevins493]
#1659238
08/16/14 02:52 PM
08/16/14 02:52 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I wouldn't trade HS rockers for Hughes I would fix the problem and keep the much better rocker that you have now.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
