Re: Suspension Advice Regarding my 69 Satellite Wagon
[Re: Sneke_Eyez]
#1797631
04/07/15 05:36 PM
04/07/15 05:36 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
Monroe gas magnums are fair performers up to around 1" diameter T-bars and are $30 per. The stock shocks will be totally overwhelmed.
11/16 tie rods and ends. Mehh, I'd save the money here and just replace your 9/16 ends. Unless you're pushing it to the limit, you aren't defelcting these enough t o justify the cost, IMO. FWIW, 9/16 ends will sustain 5g worth of loading before they fail. Any gains here are in the solid sleeves compared to the stock split sleeve. If you are adamant about solid sleeves, get swedged steel tubes from Speedway for $20 each instead of forking over big buck for billet sleeves.
Energy Suspension strut rod polyurethane - check tolerance stack up with these and how the effect your lower control arm seating position. These are often too thick and make the lower arm sit further back making caster even harder to achieve.
Fast ratio stuff, I like it. It does help with low sped maneuvering. Is unnecessary for high speed stuff.
Lock and seal kit, unless you stock ones are trashed, no need to get new ones.
[Re: autoxcuda]
#1797632
04/07/15 05:39 PM
04/07/15 05:39 PM
Posts: 321 Massachusetts
Sneke_Eyez
Massachusetts
Excellent, thank you for noticing that. So I'm looking at 2 of the K7030s and 2 of the K7103s?
1969 Satellite Wagon - G3 Hemi Swap Incoming. | 1969 Coronet Post Coupe. 2002 Intrepid ES | 2009 Ram SLT | 2004 300M Special | 2002 300M Pro Am - Hers
Are you a New England Mopar Enthusiast? Come check out the revived NorthEast Mighty Mopar at www.northeastmightymopar.com!
[Re: TC@HP2]
#1797655
04/07/15 05:57 PM
04/07/15 05:57 PM
Sneke_Eyez
Massachusetts
Lock and seal kit, unless you stock ones are trashed, no need to get new ones. Hmm, so buy a cheapo set of Monroe gas magnums. I can do that. As for the tie rod ends, the 11/16s are actually cheaper than the 9/16s, so I figure the upgrade will actually save me money. With the money saved, I can buy a set of the billet sleeves, I suppose, or a set of swedged steel tubes from Speedway. Not sure what length I'd need, though. I suppose I can measure the length of the stock ones. I understand that the urethane strut rod bushings probably aren't necessary. Don't want to mess up alignment specs. I don't know what my stock pieces look like on the torsion bars. I'll be under the car on Saturday and will evaluate. Thanks for the tips!
[Re: Sneke_Eyez]
#1797665
04/07/15 06:04 PM
04/07/15 06:04 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
Excellent, thank you for noticing that. So I'm looking at 2 of the K7030s and 2 of the K7103s? No. Just two kits of the K7103's That is the offset bushings themselves no cam eccentrics. K7030 is the wrong part number. That number is for the standard bushings with a cam eccentrics. If you need cam eccentrics you can buy them separately. Don't know the part number for that. Or just use your old ones if good.
[Re: autoxcuda]
#1797673
04/07/15 06:12 PM
04/07/15 06:12 PM
Sneke_Eyez
Massachusetts
Excellent, thank you for noticing that. So I'm looking at 2 of the K7030s and 2 of the K7103s? No. Just two kits of the K7103's That is the offset bushings themselves no cam eccentrics. K7030 is the wrong part number. That number is for the standard bushings with a cam eccentrics. If you need cam eccentrics you can buy them separately. Don't know the part number for that. Or just use your old ones if good. Thank you, much appreciated. I will update the list post with this info.
[Re: Sneke_Eyez]
#1798457
04/08/15 01:17 PM
04/08/15 01:17 PM
TC@HP2
Pikes Peak Country
If 11/16 are cheaper, why not. You would need to measure your sleeves to approximate a sleeve you may need if you don't want mopar specific units. The urethane strut bushings aren't a deal killer, just something to be mindful of checking. The thickness of them very from brand to brand so you just want to make sure you aren't putting units in that are thicker than stock. If they are, urethane can be turned down very easily. Firmer strut bushings are good for heavy braking to minimize toe changes. This is why a number of upgrade struts actually use heims as a more solid means of reducing deflection.
[Re: TC@HP2]
#1798632
04/08/15 05:07 PM
04/08/15 05:07 PM
Sneke_Eyez
Massachusetts
If 11/16 are cheaper, why not. You would need to measure your sleeves to approximate a sleeve you may need if you don't want mopar specific units. The urethane strut bushings aren't a deal killer, just something to be mindful of checking. The thickness of them very from brand to brand so you just want to make sure you aren't putting units in that are thicker than stock. If they are, urethane can be turned down very easily. Firmer strut bushings are good for heavy braking to minimize toe changes. This is why a number of upgrade struts actually use heims as a more solid means of reducing deflection. I think I'm just going to go with the regular rubber strut bushings. My biggest problem right now is that I can't get the Proforged left ball joint - they don't have any in stock and neither does anyone else who sells for them.
[Re: Sneke_Eyez]
#1804177
04/15/15 02:21 PM
04/15/15 02:21 PM
Sneke_Eyez
Massachusetts
Well I ordered it all last night - including the fast ratio pitman and idler arms. I managed to get pretty decent deals. Now I am in need of a master cylinder for my Wilwood setup: www.summitracing.com/parts/wil-140-11020/overview/year/1969/make/plymouth/model/satelliteIt is the older Dynalite caliper with the Solid surface rotor. I bought them for a great deal from a member here, and I want to install them while I'm doing the suspension work. Any advice for what to use for a master cylinder - particularly size? Thoughts on whether I should go power brakes at the same time? I'm going to keep the stock 9'' drums on the back for now - eventually they'll get swapped for 11'' drums when I convert to an 8 3/4.
