Harmonic balancer bolt coming loose
#1658521
08/13/14 11:40 AM
08/13/14 11:40 AM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
We freshened up my buddy's 528 Hemi. It had 170 passes on it. 20 since he had bought it. All we did was replace the rings and bearings and removed the roller cam and put in a flat tappet. We installed the ATI balancer with the proper tool, used an ARP bolt and torqued the balancer to the 135 ft lb stock spec. After one pass the harmonic balancer bolt was not tight, maybe had 30 ft lbs on it. We retorqued it made another pass and some idling around. Checked it again and it had around 30 ft lbs on it. Any ideas? Thank you.
2011 Drag Pak Challenger
Re: Harmonic balancer bolt coming loose
[Re: rickseeman]
#1658523
08/13/14 12:00 PM
08/13/14 12:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Are you SURE the balancer is bottomed out on the crank.. in a lot of cases 135# wont move the balancer if your trying to pull it on... I cant say why its coming loose.. I've never had that issue on my SB stuff
[Re: Airwoofer]
#1658526
08/13/14 01:34 PM
08/13/14 01:34 PM
Posts: 1,443 Maryland
Dads426
Maryland
The new ATI balancer we installed at the beginning of this year would not go on all the way unless it was honed out. On some aftermarket cranks the tolerances are a little on the high side making the fit too tight.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#1658527
08/13/14 01:58 PM
08/13/14 01:58 PM
Posts: 1,134 OHIO THE HEART OF IT ALL
64hemi330sedan
been there done that. I learned the hard way. I cracked the hub and had to buy another one. honed the new one as per there instructions. I used blue Loctite on my arp crank bolt. i hope it stays tight.im hoping to fire it up here soon.
[Re: Cab_Burge]
#1658531
08/13/14 02:56 PM
08/13/14 02:56 PM
Posts: 10,232 Someplace you aren't
SomeCarGuy
Make sure the damper is fully seated with the tool, then run the bolt down to spec. Then a short burst with the impact. If you don't do the impact, you can't roll the engine over by hand.
I want my fair share
[Re: Thumperdart]
#1658537
08/13/14 10:50 PM
08/13/14 10:50 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Clean the threads and put it on with red loctite ???
I`ve always impacted em on probably close to 110-120 ft. lbs. w/red loctite and they never have come loose.........
Me too !
[Re: rickseeman]
#1658540
08/14/14 02:50 PM
08/14/14 02:50 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
A balancer bolt should not need Loctite to stay tight. The dampner, if done correctly is a press fit, on a straight shaft. There shouldnt be much load trying to " push" it off the crankshaft.Although belts and drive accessories could contribute, especially if out of balance) The press fit holds the dampner on, not the bolt. The bolt is a safety precaution more than anything. Its a massive 3/4" bolt, it takes a lot to hurt one, and a lot to torque one. The only things that SHOULD loosen a dampner bolt by itself are: A bad dampner, or a bad balance job ( or components) A dampner that is not fitted properly or pressed on all the way. Sometimes the hard finish of the ARP type bolts need a burnishing with a wire wheel etc as they tend to be slick as finished, or covered in protetcive oils. Make sure to spray some brake clean etc in the damper hole fo the crank. to make it grease free and dry. My
RIP Monte Smith
