Street Demon carb/stock air filter fit?? #1658201
08/12/14 04:41 PM
08/12/14 04:41 PM
Lakeland FL
floridian Offline OP
Lakeland FL
Been looking at and reading about the new Street demon carbs.. I have been wanting to update the stock AFB on my 67 440...
Would this carb be a bolt on?? I understand the electric choke, but would my stock linkage ( throttle and Kickdown) bolt up and would my air cleaner work?? Appreciate any knowledge on this..
If not I assume a new Edelbrock ( avs) will??
67 Coronet 440/727
Re: Street Demon carb/stock air filter fit?? [Re: floridian] #1658202
08/12/14 11:51 PM
08/12/14 11:51 PM
Motown, Mi
P
PAULS_340 Offline
PAULS_340  Offline
P
Motown, Mi
Me and my buddy just got two of the Street Demon 625's, you'll probably get the 750, but both of ours bolted on and all linkage bolt right on. I had to use a carb spacer because of my spreadbore intake.
Still looking for LM29H1B415501, '71 Demon 340
Re: Street Demon carb/stock air filter fit?? [Re: floridian] #1658203
08/14/14 06:33 AM
08/14/14 06:33 AM
Central New York
bfury Offline
bfury  Offline
Central New York
I bought a 750 for my 340. The stock throttle stud would not work since it comes in from the back side of the arm on the carb without taking the carb apart. I had to order the street demon mopar stud at $25. You would think that the stud threads would screw right in to the throttle lever but I had to use a nut. The carb works great. The best I ever have had and that includes TQ's, eddy' and holleys. The air filter I have worked, it is the black mopar flat top die cast air cleaner.
No Stock
Re: Street Demon carb/stock air filter fit?? [Re: bfury] #1658204
08/14/14 01:00 PM
08/14/14 01:00 PM
Lakeland FL
Lakeland FL
I have the stock "dual snorkel" on mine and would like to continue using it????
Re: Street Demon carb/stock air filter fit?? [Re: floridian] #1658205
08/14/14 02:38 PM
08/14/14 02:38 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Mine is a Speed Demon, but pretty close.
On my stock dual snorkel, the choke linkage near the top (at the butterflies) just barely hung up on the rim of the air cleaner. The smallest amount of bending and tweaking on the air cleaner base and then it cleared just fine. It took barely any bending at all, and it is on the bottom, so it is not visible anyway.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Street Demon carb/stock air filter fit?? [Re: wingman] #1658206
08/15/14 05:41 PM
08/15/14 05:41 PM
Lakeland FL
Lakeland FL
Everyone like there speedemon carbs?? Any naysayers?
Re: Street Demon carb/stock air filter fit?? [Re: floridian] #1658207
08/15/14 05:55 PM
08/15/14 05:55 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
The "Speed Demon" is basically an update of the Holley design. That's what I have and I like it. They have been around for a while.
The "Street Demon" is basically a rework of the Thermoquad design. They are newer and I have no firsthand experience with those. Sorry...
