Re: hemi piston to head clearance specs or minimum....
[Re: ogopogo]
#1657374
08/11/14 03:52 PM
08/11/14 03:52 PM
Posts: 1,505 TN
SCATPACK 1
TN
Follow what Cab said and shoot for 35 to 40 thousands piston to head clearance. The old manuals were for a different metal in the pistons that expanded more. If yo were using aluminum rods, I would recommend more clearance. But that should give you good quench (if there is such a thing on a HEMI).
Old Geezer Racing
[Re: SCATPACK 1]
#1657376
08/11/14 04:17 PM
08/11/14 04:17 PM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
You can't check a Hemi for dome to head clearance through the spark plug hole with a dial indicator.
I would disagree with that. Seems like the easiest way to me. Mock engine up, piston at TDC, place dial indicator in spark plug hole, zero indicator, remove rod bolts, push up rod until piston hits head, read distance on indicator.
P.S. Don't use too much clay checking valve to piston clearance. Don't ask me how I know.
2011 Drag Pak Challenger
[Re: rickseeman]
#1657379
08/11/14 06:32 PM
08/11/14 06:32 PM
Posts: 1,505 TN
SCATPACK 1
TN
Rick, Well duh on my part. I am going to chalk it up to "my sometimers" memory. I knew that... Not sure what I was thinking earlier, so disregard my first post.
Old Geezer Racing
[Re: Jim I]
#1657382
08/11/14 10:16 PM
08/11/14 10:16 PM
Posts: 1,313 Charlotte, NC
LSP
Charlotte, NC
.058 to .060 minimum clearance. check it with a dial indicator thru the spark plug hole.
This is correct, the clearance needs to be measured vertically, the Super Stock Hemi builders do it this way.
While .055" radial clearance is more than is required and will undoubtedly 100% keep the piston from ever hitting the head in that plane, performance will not be optimum.
[Re: LSP]
#1657383
08/11/14 10:56 PM
08/11/14 10:56 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Measuring with the indicator will give you the precise clearence of any part of the piston that is closest to the head.For most engines used for street and bracket racing a little extra clearence is good insurance against a catastrophic hic-cup.On any scienced out class race type engine the tighter the better.We used to get the dome as close as possible untill we saw shiney areas on the dome,but no contact marks.This was great for making power but put the engine close to "kill"with the slightest screw up.This can be quite costly.If you want a fast engine by all means tighten it up,if you want a dependable engine that will give you good performance and longitivity give it some extra.
