Weird vibration just backing off throttle
#1657337
08/11/14 04:54 AM
08/11/14 04:54 AM
Posts: 885 alberta
Publicbottle
alberta
Hope I can find some advice here to steer me in the right direction. 1970 Challenger, everything is either new or rebuilt. 340 833OD, I have a new strange 60 rear end and driveshaft. I get a horrible shudder/vibration just as I let off on the gas. Happens mostly in 4th gear on the highway. Happens in other gears too but definetly most noticeable in 4th. If Im cruising at 70mph, pull out to pass someone touch about 80mph then let off the throttle I get this vibration. It almost sounds like the trans is "freewheeling" if that makes sense, resonates throughout the whole car with a buzzing vibration. But if I keep on the gas just a touch it will not do it. Also if I depress the clutch during this, it still occurs and no change is noticed. Im going to pull/inspect the driveshaft and u-joint stomorrow, otherwise What do I look for next? Driveline angles?? Car shifts fine otherwise. Thanks for the help!
Re: Weird vibration just backing off throttle
[Re: Publicbottle]
#1657338
08/11/14 10:50 AM
08/11/14 10:50 AM
RapidRobert
When you pull the driveshaft check how much end play you have into the trans. EDIT check angles too
[Re: Cab_Burge]
#1657346
08/12/14 11:46 AM
08/12/14 11:46 AM
Posts: 1,567 Ky
jt4406
Ky
70 440 4 speed challenger, had the same vibration, had my driveshaft balanced, solved the problem. jess
Yeah, it's hopped up to over 160...
[Re: jt4406]
#1657347
08/12/14 02:45 PM
08/12/14 02:45 PM
Posts: 885 alberta
Publicbottle
alberta
I am assuming my driveshaft is balanced as it was made for my application from strange. also looking at it you can see a couple tabs weights welded to it.
[Re: Publicbottle]
#1657348
08/12/14 03:52 PM
08/12/14 03:52 PM
Posts: 885 alberta
Publicbottle
alberta
Just went out to check my angles......now let me make sure I am doing this right, sorry I know this has been beaten to death here.... I have a digital angle finder. Car is on the ground, level surface. Full tank of gas. Ready to drive. I zero my angle finder on the the ground Therefor my pinion angle and trans output angle are relative to the ground, correct? If so, these are the measurements I got (relative to the ground "zero") rear pinion angle is 8.6 degrees up! transmission ouput is 1.3 degrees down. Doesnt this seem way off? Or maybe herein lies the problem? Did I put my angle shims in backwards??
[Re: Publicbottle]
#1657352
08/12/14 10:32 PM
08/12/14 10:32 PM
RapidRobert
If the trans output shaft is 1 deg down from horizontle and the driveshaft is 2 deg down from horizontle then the front ujoint (the important piece here) is 1 deg down since it is 1 deg "further" down than the trans shaft. The shaft will be 2 deg down from horizontle also on the other (pinion) end & you would want the pinion ~5 deg down from horizontle as it will rise ~2 deg on accell to only be 3 deg down from horizontle and since the shaft is 2 deg down from horizontle the rear ujoint (the other important piece) in effect is 1 deg "up" from the pinion. On accell the front ujoint being 1 deg (further) down than the trans and the rear ujoint is 1 deg (further) up than the pinion (which rises 2 deg) means they are parallel in different planes. You measure angles to ground to see what angles you have on the angle finder but its the angles of the ujoint (shaft) to the front yoke (trans) and the angle of the rear ujoint (shaft) to the pinion that count (& cause the problems if they ain't right) as in too much angle. How much the pinion rises depends on power/strip/street/daily driver etc. Messure your angles & post em. Have the car level side to side and end to end for accuracy
[Re: Publicbottle]
#1657355
08/13/14 07:07 AM
08/13/14 07:07 AM
RapidRobert
The front ujoint is .7 deg down and the rear ujoint is 6.6 deg down. Not good. I would put the fat part of the perch shims to the rear to rotate the pinion down to where it is closer to 2.7 deg down from horizontle (which makes the rear ujoint .7 up) plus a bit further down from that to account for the pinion rise. 2 deg addit'l sticks in my head but that might be for hot accell and not a DD so check on that. but yes the pinion is way too high. when done check the angles again & you want more than .7 deg difference in the front ujoint to trans & depending on what you end up with after adding the angled perches you might want to add another pair of OE shims on the bottom of the trans to raise it some to increase that angle (want more than .7 diff). I ain't sure if you can lower the pinion that much (that you need) with angled perches & you definitely might want to raise the trans to reduce the change needed. Holler when you can. EDIT for now I'd put the angled perches in (thick to rear) & see what that does for the vibration
