Rear Shackle Location #1657256
08/10/14 11:33 PM
08/10/14 11:33 PM
PA
dumbdog70 Offline OP
PA
On my 70 Challenger the rear shackles are about at the 1 and 11 oclock position. Is this acceptable? I think I saw somewhere that 2 and 10 oclock positions were preferred. Also with my ss springs should I be running a pinion snubber? I do have the mp longer shocks. What adding other clamps?
Re: Rear Shackle Location [Re: dumbdog70] #1657257
08/11/14 12:19 AM
08/11/14 12:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Should be about 35* to 45*... if your SS springs are
any good you dont need a snubber,,, the car should lift
with out one... the bottom of the shackle should be
to the rear... clamp all front segments... and decent
adjustable shocks at all 4 corners... minimum 9 way
Ranchos on the rear and maybe the Caltrac fronts
Re: Rear Shackle Location [Re: MR_P_BODY] #1657258
08/11/14 12:52 AM
08/11/14 12:52 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
E-body's are a tough fit....I went with adjustble shackles and cut the lowest position off because it wold hit the valance...
