Re: pinion number
[Re: Crabra]
#1657252
08/10/14 11:43 PM
08/10/14 11:43 PM
RapidRobert
post all you want bro there is no limit. I would put a piece of flat stock across one of your rear tires and measure down to the ground for your dia & even better would be to get the dia from "rollout". Out in your parking lot get a rear tire valve stem at 6 o'clock and set a brick on the ground at that point then roll the car forward in a straight line till the stem is back to 6 o'clock then tape measure that distance and divide 3.1416 into your measurement to get the exact dia. Jack the car way up on the DR side to minimize tha amt of fluid you'll lose when you change pinions & dont forget to clock the adapter to the right position to match the teeth number grouping for your pinion teeth count
Re: pinion number
[Re: Crabra]
#1657253
08/11/14 01:36 AM
08/11/14 01:36 AM
Posts: 32,978 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
I was in the tech archive. How do you think I came up with the number.
I don't know how you came up with that number you didn't bother to say. I posted that link to help.
Re: pinion number
[Re: Crabra]
#1657254
08/11/14 03:03 PM
08/11/14 03:03 PM
Posts: 25,975 Rio Linda, CA
John_Kunkel
Rio Linda, CA
255/60r15 tire and 3.55 gears requires a 34 tooth pinion; current P/N is 52068156...green in color.
