Re: Hemi intake bolts keep coming loose
[Re: quickd100]
#1657117
08/11/14 11:36 PM
08/11/14 11:36 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Greg; It was nice to talk with you last week. Your gaskets came last Thursday and after torqueing the intake about 5 times it has taken a set. (The other gaskets took 10-12 retorquings). Thank You! Dave
Dave the pleasure was all mine!
I sure hope you were able to notice the quality difference in materials we use for our gaskets
I would also like to add some abbreviated installation techniques to aid with installation. Assuming your all set to go, angles checked, surfaces clean and inspected, etc..
Determine weather you want the gasket attached to the intake or cylinder head.
Apply a coat of 3M Super 90 spray adhesive to the back side of gasket, A couple passes should be sufficient. Apply gasket to surface while wet and peel back off. Allow to tack up for 5-10 minutes then re apply the gasket to the surface for the final time. Be careful with alignment it sticks immediately
After spray adhesive has fully cured apply some white lithium grease to the opposing side of the gasket. This helps with the Hemi intake wedge itself into position while being torqued.
Apply a sparing amount of Hylomar Universal Blue to the bolt threads and follow normal torque procedures. Re-check torque until everything has settled and you should be good to go on the gaskets.
[Re: roadhazard]
#1657118
08/11/14 11:56 PM
08/11/14 11:56 PM
Posts: 12,591 Great Neck,LI,new york
hemi-itis
Greg, Thanks for stepping in how do I determine what thickness gasket I need? How do you seal the front & rear of the intake manifold??
