ECUs, all the same?
#1656963
08/10/14 11:23 AM
08/10/14 11:23 AM
Posts: 4,051 Connecticut
jeff968
Connecticut
The Challenger had a few issues starting over the past couple of months. Turns out the problem was the ECU. I had the Orange one from the Mopar performance electronic ignition kit. Although the kit was 5 years old it only had about 2,500 miles on it. The ECU looked new. Any recommendations on a replacement model (I have a used ECU in the car now)? Are the orange ones garbage or is that about the life to be expected? Thanks
1970 Dodge Challenger T/A
Re: ECUs, all the same?
[Re: stumpy]
#1656967
08/10/14 05:50 PM
08/10/14 05:50 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
I disagree. Got two chromed broken in a row, one of them just last long 24 hours of useage... fixed both replacing the power transistor ( temporally ): fixing Chromed boxes This has being also threated here in Moparts, but taking my initial topic in DC.com
[Re: 74RALLYE]
#1656971
08/10/14 06:08 PM
08/10/14 06:08 PM
NachoRT74
Valencia, España
My orange box died with less than 1000 miles on it. I picked up a few chrome boxes at the junk yard 10 years ago and haven't had to replace any of them.
yes, maybe thats the old boxes when good transistors came up from manufacturers, as I said, but not newers ( dunno the LATERS ), where the chinesse electronic junks are all around.
Anyway, is just a theory, but I think I have "prooved" some on my experiment
[Re: NachoRT74]
#1656972
08/10/14 07:11 PM
08/10/14 07:11 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Nacho.. In looking @ changing out the power transistor I find no mention of using the insulating thermal grease... Thermal grease is absolutely required for bonding the power transistor properly to the insulator to its heat sink mounting. Without this the power transistor can heat up, burn out and fail. As it is not using the heat sink to help cool it down.. Here is a link to a YouTube video for the proper procedure. https://www.youtube.com/watch?v=hNRacVQRgBcJust my $0.03...
[Re: Sinitro]
#1656973
08/10/14 07:34 PM
08/10/14 07:34 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Just my $0.03...
HaHaHa!! that was my old Xbox 360's problem!
[Re: jeff968]
#1656974
08/10/14 10:35 PM
08/10/14 10:35 PM
Posts: 75,064 U.S.S.A.
JohnRR
U.S.S.A.
Pretty much , switch to a pertronics , they make one that works in the electronic distributor , the plus is the ugly orange piece of garbage , the ECU not your car , will never leave you stranded or wanting for more ...
... que the orange box sword swallowers in 3 ... 2 ... 1 ...
[Re: JohnRR]
#1656975
08/10/14 10:55 PM
08/10/14 10:55 PM
RapidRobert
Groundbreaking stuff Nacho , If I can find a dead one (of any color) & source that transistor I'm gonna give it a shot. I've never ran orange boxes enough to have one fail but from the multitude of neg comments I definitely would not purchase a new (orange) one
[Re: RSNOMO]
#1656978
08/11/14 02:00 AM
08/11/14 02:00 AM
JohnRR
U.S.S.A.
I find it amusing that in your world, 8 3/4 rear axles(which lived in millions of Mopars)...
And electronic ignitions(which powered millions of Mopars)...
Do not live up to your exacting standards...
A cheap, imported POS component does not trash an entire concept...
And do you really think pertronix is some sort of gift of divine intervention???
[Re: SattyNoCar]
#1656980
08/11/14 06:50 AM
08/11/14 06:50 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
In 20+ years of driving...
And rolling-up 20,000+ miles on the odo...
I've lost one orange box...
It's been mentioned here (by my self also) that the orange boxes built within the last 10 yrs or so are garbage. The old(er) ones actually worked pretty good and held up well.
I had an orange box I bought way back in '90, and had it on three different daily drivers putting well over 150K miles on the unit before it began to die in '02 (developed an intermittent short).
That seems to be as it seems most of the orange boxes that are bad seem to have been bought after 2000 as many that say they are junk bought them after 2000 and maybe Mopar changed the vender around them as who knows how many venders they have used over the years ? I do know I bought my orange box about 1999 and its still on my 63 working good pushing it into the 10's. Also many have reported the newer orange boxes that did not die are taking timing out at higher rpms. Mine seems to not be doing that as we had my orange box on my boys Dart and when we swapped it to MSD it ran the same as it was no faster and started the same. That said if you want to use the MP I would use the chrtome box as less seem to complain about them having trouble. Ron
