Valve to piston checking question #1656741
08/09/14 04:03 PM
08/09/14 04:03 PM
WI
68hemiss Offline OP
68hemiss  Offline OP
WI
I have a question on checking valve to piston clearance with a hyd cam. Should I use a solid lifter when checking - won't the hyd lifter give a false reading - not being pumped up?
Re: Valve to piston checking question [Re: 68hemiss] #1656742
08/09/14 05:11 PM
08/09/14 05:11 PM
Minn
SportF Offline
SportF  Offline
Minn
Use a solid lifter, or put a small washer in there to make it act like one. That will only work with a weak checking spring" though.
Re: Valve to piston checking question [Re: 68hemiss] #1656743
08/10/14 01:10 AM
08/10/14 01:10 AM
tn
robnbird Offline
robnbird  Offline
tn
Just use a solid lifter , that will be accurate enough
Re: Valve to piston checking question [Re: SportF] #1656744
08/10/14 01:24 AM
08/10/14 01:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
And take your reading at the valve to make sure it is
traveling the distance it should be.. if your using
adjustable rockers you can adjust the rocker to make
sure you are getting full lift... if the solid or
what ever you use is a different height you could
end up short on the lift
Re: Valve to piston checking question [Re: MR_P_BODY] #1656745
08/10/14 04:39 AM
08/10/14 04:39 AM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
isnt it likely that the solid lifter will have a different pushrod cup height than the hyd lifter?
can you use a hydraulic lifter but make sure its full of oil?
Re: Valve to piston checking question [Re: ogopogo] #1656746
08/10/14 05:17 PM
08/10/14 05:17 PM
if you use a very light pressure checking spring and make absolutely sure the hydraulic lifter does NOT collapse any, then yes you can Set the lash at zero and watch the lifter cup to retaining ring clearances and go from there Let us know what you find out another messy option is to prime the motor while doing the PtoV checking I've done that also
