Re: Gear Change
[Re: mokid]
#1656508
08/08/14 11:53 PM
08/08/14 11:53 PM
Posts: 52,972 Romeo MI
MR_P_BODY
small block R3 W8 830 HP car weight 2830 LB we launch at 5200 RPM go thru trape at 8200 RPM
I trap at the same rpm but use a 4.56 gear(this is with my W-9 405ci)... I think your turning more than the peak HP by more than the 10% that I like to run
Re: Gear Change
[Re: mokid]
#1656511
08/09/14 01:48 AM
08/09/14 01:48 AM
MR_P_BODY
What are you 60 ft. I was surprised Strang said if I went to a 4,89 my MPH would go to 156,
Best is 1.19... normal is 1.20-1.21
Re: Gear Change
[Re: mokid]
#1656513
08/09/14 10:11 PM
08/09/14 10:11 PM
MR_P_BODY
149 MPH at 8300 rpm
Is it still pulling good at that rpm.. I think my engine was running out at 8200 and 152.. I was thinking about going 4.30s but I sold the engine and have to use my back up and run slower(only aloud to run 10.0 now due to health)
Re: Gear Change
[Re: mokid]
#1656515
08/09/14 11:41 PM
08/09/14 11:41 PM
MR_P_BODY
I believe its at it peak maybe a little more in it,
I just dynoed my on a chassis dyno so the best I could figure is it made peak HP at 8000 and I went through the traps at 8200 but it seemed like it was out of power before that.. thats why I wanted to try the 4.30s but if you have a engine dyno sheet that says you make peak at 7900 or so you should be in the park
Re: Gear Change
[Re: mokid]
#1656517
08/10/14 01:18 PM
08/10/14 01:18 PM
MR_P_BODY
Yes our dyno sheet does shoe peak at 7900
Just a guess here but you could be running out of power like I think I was and the lesser gear might help.. but if your torque curve is falling off like mine, then I think a lesser gear could help.. just a guess
