Re: Idle tuning problem
[Re: mt162]
#1656487
08/08/14 05:23 PM
08/08/14 05:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Two things if the timing is going back to the base timing... make sure the blades are closing to the right point and if so blow out the mixture screw holes.. but normally the timing is slow returning to base.. clean and lube the dist weights
[Re: mt162]
#1656496
08/10/14 10:41 AM
08/10/14 10:41 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
What are the cam and motor specs? I'm wondering if it needs more initial advance to carry the idle. twist dizzy up 5 to 10 degree to test idle at that spot (not drive) just to see what gives a better idle adjustability. I use mopar springs in my MSD to give quicker advance and thus more idle advance.
[Re: MR_P_BODY]
#1656500
08/10/14 06:36 PM
08/10/14 06:36 PM
Posts: 123 Indiana
mt162
Indiana
Also, high float levels will cause this
That may be it. I have them adjusted way down but it seems like they seep out of the holes more than they should. I wrote it off as from engine vibration but now I think maybe the needle and seat may be leaking a little.
[Re: Thumperdart]
#1656502
08/11/14 02:42 PM
08/11/14 02:42 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
distributer gunked up and weights are sticking
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
