power steering coupler interchange #1656397
08/08/14 03:44 PM
08/08/14 03:44 PM
Cambridge, Ontario, Canada
CUDAJAS Offline OP
CUDAJAS  Offline OP
I need a power steering coupler for my cuda (switching to power from standard)
I know the couplers are not car specific, but what year did the coupler change.
Is it possible NAPA etc have one but under a newer model?
Jason
Re: power steering coupler interchange [Re: CUDAJAS] #1656398
08/08/14 04:24 PM
08/08/14 04:24 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
if we are talking about this:
and talking about a Cuda, you'll need to change the coupler body just because the diff size of the steering box splined stud ( smaller on powered ), not really due the year. The year change was waaaaaay earlier
Maybe will need to change the column shaft too? due the diff lenght? dunno
Re: power steering coupler interchange [Re: NachoRT74] #1656399
08/08/14 04:40 PM
08/08/14 04:40 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
Yep that is the piece we are talking about.
I have already changed the shaft and the I know the standard coupler will not fit the power box.
My questions is what year did the stop using that type of coupler?
I have seen the aftermarket ones, but man are they pricey!!!
Jason
Re: power steering coupler interchange [Re: CUDAJAS] #1656400
08/08/14 05:20 PM
08/08/14 05:20 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I think they stop to use it in erliers to mids 80s ?... when cars began to be FWD dunno
Bouchillion got them new in $112 ( ouch!!! )
http://www.bpeusa.com/BPE2218.asp
but just in case:
http://www.ebay.com/itm/Mopar-1967-and-U...a91&vxp=mtr
kits available everywhere
Re: power steering coupler interchange [Re: NachoRT74] #1656401
08/09/14 11:20 AM
08/09/14 11:20 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
My friend (70aarcuda) put in a universal joint on his cars(70 & 71 abody). I think it would be better than getting another stock unit. PM him and he will tell you where he got his.
Re: power steering coupler interchange [Re: babarracuda] #1656402
08/09/14 12:55 PM
08/09/14 12:55 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I have my serious reserve about those universal joints... On chassis cars they can work NICE, but not on unibody frames, since the body flex, and the Coupler designed by Chrysler allows this flex without affect the steering shaft assembly. That's the reason for this kind of coupler
Re: power steering coupler interchange [Re: NachoRT74] #1656403
08/09/14 01:46 PM
08/09/14 01:46 PM
Horsham, Pa.
Finoke Online content
Finoke  Online Content
Horsham, Pa.
Hey Jason,
I just went from power steering to manual steering. I have the complete original power steering coupling from my 70 challenger. It has everything you need except the roll pin that holds it on to the shaft.
PM me if interested. I will give you a good deal if your interested.
Tom
Re: power steering coupler interchange [Re: Finoke] #1656404
08/11/14 12:27 AM
08/11/14 12:27 AM
CUDAJAS Offline OP
CUDAJAS  Offline OP
Hey Jason,
Tom
Hey Thanks man.
I appreciate the offer. I really need one in the next day or so in order to make the big show (Moparfest) this coming Saturday.
Given you are in PA and I am in Canada, probably not gonna get here in time.
If I cant find one, I will let you know.
Jason
Re: power steering coupler interchange [Re: CUDAJAS] #1656405
08/11/14 07:24 AM
08/11/14 07:24 AM
Hamburg, Pa.
72 RR DUDE Offline
72 RR DUDE  Offline
Hamburg, Pa.
Didn't know you had to change the coupler. Went from standard steer to power on my 72 RR and had to only change the shaft because of length. What is the difference in the coupler???
Re: power steering coupler interchange [Re: 72 RR DUDE] #1656406
08/11/14 10:54 AM
08/11/14 10:54 AM
CUDAJAS Offline OP
CUDAJAS  Offline OP
The input shaft on the steering boxes are different sizes.
Are you sure you did not change the coupler.
Can some one please confirm that the input shafts are different sizes?
Jason
Re: power steering coupler interchange [Re: CUDAJAS] #1656407
08/11/14 01:03 PM
08/11/14 01:03 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
well, you can actually try it right now... your actual coupler into the newer manual box... or simply measure the diameter input shaft on both boxes you have at this moment
Re: power steering coupler interchange [Re: NachoRT74] #1656408
08/11/14 01:07 PM
08/11/14 01:07 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
yep, but I am at work and not near the car.
Everything I read indicated that you need a different coupler.
I will check tonight.
Jason
