Re: Plating bolts
[Re: president61]
#1656027
08/07/14 04:50 AM
08/07/14 04:50 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Suspension bolts are mostly phosphated, aka Parkerized, same as the gun metal finish on military weapons.
You can DIY phosphating at home in your spare time with gunsmithing chemicals and a garage sale stainless electric skillet.
You can DIY zinc plating with a battery charger or power source, and you can do home chromating also. Chromate is a dip for newly electro-zinc plated parts that increases corrosion resistance and changes the color to yellow-rainbow, black, etc. Google is your friend.
In the past I have offered zinc anodes for plating here on Moparts parts for sale. Some day maybe I'll post how to get started with electro-zinc plating and chromating. Meantime I'm busy with restoring. Sorry.
Re: Plating bolts
[Re: kentj340]
#1656028
08/07/14 08:24 AM
08/07/14 08:24 AM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
http://www.shootersolutions.com/parkerizing.htmlI've used the heavy duty manganese/zinc on 3 antique Harleys , a Browning 1919 .30 cal machine gun, and several parts on my Bee. Works great! I use a 2 burner hot plate and turkey roasting pan for most parts and for longer pieces, gun barrels and gas tank straps, have a long wooden box to soak the piece in. I sealed the inside of the box so solution won't leak out. http://www.caswellplating.comFor zinc electroplating kits.
