edelbrock carb issues
#1655567
08/05/14 11:12 PM
08/05/14 11:12 PM
Posts: 257 albemarle, NC
dusterbd13
albemarle, NC
so ive ben fighting carb issues in my duster for a while. its bad enough to where ive all but stopped driving it.
idle mixture is set properly with a vacuum gauge, with the ac compressor on, fully warmed up.
electric fuel pump, regulated to 5.5 psi.
floats set to 1/2 from the carb gasket to the top of the float with the cover inverted.
stock jets, rods, and springs.
3/8 thick insulating carb gasket.
air gap intake
so my issues are a few fold. 1. will not restart hot. seems to be vapor locking. 2. doesn't pull nearly as hard as with the 850 double pumper I had. 3. erratic idle with ac compressor on. 4. diesels on cutoff.
while adjusting float level tonight in a vain attempt to solve the hot start issue, I forgot to put the metering rods and springs back in. no covers either. the car ran significantly better when I got on it. almost like the old double pumper. I was excited. when I put the rods back in, it was back to its same old tricks. I don't know if it was all in my head, but with no rods or covers the hot start issue seemed all but gone, but I didn't really validate that well. also didn't seem to even think about dieseling.
so what am I missing? im thinking that the rod and jet combo is way too lean, causing most my troubles, and the springs too stiff. does this sound right?
please, help me out here. I just want to finish out until my leg surgery driving this car.
Michael
Re: edelbrock carb issues
[Re: dusterbd13]
#1655571
08/06/14 01:11 AM
08/06/14 01:11 AM
RapidRobert
reset floats to 7/16" and go 3 thou richer on the jets. Which eddy? what springs/what cam/what idle speed. EDIT richen the idle mixture screws
[Re: RapidRobert]
#1655572
08/06/14 08:48 AM
08/06/14 08:48 AM
Posts: 15,487 Florida
scratchnfotraction
![](/ubbthreads/images/graemlins/iagree.gif)
if it ran well with no needles/step up pistons/covers in the pimary jets it is way lean and that made it more than fat with a huge vac leak.
I just went from a 600 eddy to a holley 6210 650cfm spredbore dbl pumper and cant believe how much better mine runs.
ditch the eddybroke
![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Mr.Yuck]
#1655574
08/06/14 12:46 PM
08/06/14 12:46 PM
Posts: 4,961 WI
Dcuda69
WI
Then put that back on.
Yep! or any Holley. There's more threads around complaining about the eddy carbs. I know the Eddy lovers will chime in but......oh well,here's some info for ya ![](/ubbthreads/images/graemlins/beer.gif)
https://board.moparts.org/ubbthreads/show...e=3#Post8218208
[Re: dusterbd13]
#1655576
08/06/14 03:43 PM
08/06/14 03:43 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I have always been able to get an engine to run little harder with a Holley but have much better manners and mpg with the CarterBrocks. Since I don't race it was an easy decision. AFB wins. The AFB is no harder to tune than a Holley. The same basic problems happen with each style of carb. Some issues show themselves in different ways. It really helps to have eyes and hands on the carb to be able to determine the problem. It could be something as simple as a poor vacuum signal to the carb due to the lumpy cam. If the primaries are opened too far at idle it can uncover the transfer slots. When that happens you'll never get it running right. 1/2" is too deep for the floats. Back that down a bit as suggested. Get the front end dialed in for good cruise and idle. Leave the back half for making power. Quote:
1. Could be an ethanol fuel issue. The AFB fuel bowls sit directly above the manifold and aren't as isolated as the Holley carbs.
2. It should give close performance but the much larger Holley will likely make more power. In fact, I bet the 850 would pull harder than a Holley sized to match the AFB.
3. A/C compressor is going to pull either carb down. Basic physics there. If it didn't impact the 850 as much it was a sign that you likely had the idle tuned less than perfect.
4. Dieseling on cutoff is likely due to hot fuel and/or excessive timing.
The Carter AFB has a better reputation than the Edelbrock. The Eddy 750 has been a poor performer since inception due to poor reverse engineering. I understand the larger AFB has a better reputation. Eddy carbs have different jetting out of the box based on manual or electric choke.
[Re: dusterbd13]
#1655577
08/06/14 05:53 PM
08/06/14 05:53 PM
Posts: 15,526 Omaha Ne
TJP
Omaha Ne
air gap intake
Michael
#1 is a known edelbrock issue, GOOGLE Edelbrock heat soak, Edelbrock, hot start, Edelbrock percolating
#2 There is a large difference between a 600 and 850 CFM so I am not surprised. My thought is the 600 may be a sit small while the 850 is too large.
#3 Tuning issue or may need an idle step up solenoid
#4. Tuning, idle is too high, see #1
