Re: Street hemi intake and carbs
[Re: Cuda367]
#1655391
08/05/14 11:01 PM
08/05/14 11:01 PM
Posts: 7,496 Minnesota
Hemi_Joel
Minnesota
I did some dyno testing on this. The Vanke modification, with 750 carbs was worth about 20 rear wheel horse over stock intake and carbs, and is a very easy modification to do. A stock intake, completely gutted an turned into a single plane is worth 35 horse over a Vanke.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Cuda367]
#1655395
08/08/14 12:52 AM
08/08/14 12:52 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Contact www.restorick.com and ask him to put you in contact with Domingo, he can get a steel Hemi scoop made for you. Not cheap but they are very convincing replicas. If you need a source for some stock appearing Hemi carbs with 750 (or more) CFM each, I can help you with that!
[Re: Cuda367]
#1655396
08/08/14 05:46 PM
08/08/14 05:46 PM
Hemi_Joel
Minnesota
Thanks Joel for the replies. I guess you are the only one on here to have worked on a street hemi. I see you are doing a RO23 car. we would like to get our hands on a factory or steel hood scoop any ideas where?
Kramer has a real one on Ebay right now:
http://www.ebay.com/itm/Original-Hood-Sc...421&vxp=mtr
Nothing against Domingos' scoop, but if you are restoring a real RO23, I would use an original scoop if possible.
