Re: In car Hemi valve spring compressor [Re: CCG] #2199154
11/19/16 10:48 PM
11/19/16 10:48 PM
IL
E
EDG Offline
EDG  Offline
E
IL
I was wondering if you still have pictures and if the phone number is good. I'm looking for a head on valve spring compressor for a 428 Hemi. Thanks for any help. Contact Ed at hemirr69@gmail.com
Re: In car Hemi valve spring compressor [Re: SNK-EYZ] #2199168
11/19/16 11:16 PM
11/19/16 11:16 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Have not used mine in many years smoke
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: In car Hemi valve spring compressor [Re: EDG] #2199212
11/20/16 01:03 AM
11/20/16 01:03 AM
San Diego CA
65 Hemi Offline
65 Hemi  Offline
San Diego CA
I am in need of one also. Please PM me if you want to try to get the multi purchase discount
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: In car Hemi valve spring compressor [Re: CCG] #2199284
11/20/16 10:07 AM
11/20/16 10:07 AM
IL
E
EDG Offline
EDG  Offline
E
IL
I'm looking at the valve spring compressor made by Richard Troutt. I like the two position handle, I think that's the way its made? How hard is it for one guy to use? I'm an old man,but I can still power shift,anyway is his number still good . I would rather have the Mancini style one if anyone got one to sell. I'm replacing valve seals. I think by now after searching for a spring compressor I could of just pulled the heads and been done. Thanks for any info. Ed Also do you have to remove the rocker arms to use RT style? Thanks again
Re: In car Hemi valve spring compressor [Re: EDG] #2199319
11/20/16 12:11 PM
11/20/16 12:11 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
Not sure it will work for you but check amazon for a compressor made for a pinto (ford) motor. That is what I have used, but I'm running a hydraulic roller so spring pressure is not real high. I just looked and it is listed under "sealed valve spring compressor "
can 13
Re: In car Hemi valve spring compressor [Re: SNK-EYZ] #2199439
11/20/16 04:52 PM
11/20/16 04:52 PM
hemi-itis Offline
hemi-itis  Offline
The tools with the hook require you to remove the rockers,,,,,,
Re: In car Hemi valve spring compressor [Re: SNK-EYZ] #2207598
12/04/16 03:20 PM
12/04/16 03:20 PM
CrazyD Offline
CrazyD  Offline
Has anyone bought the Richard Troutt compressor, and how did it work for you?
thx
Re: In car Hemi valve spring compressor [Re: SNK-EYZ] #2211773
12/11/16 12:52 PM
12/11/16 12:52 PM
CrazyD Offline
CrazyD  Offline
btt
Re: In car Hemi valve spring compressor [Re: CrazyD] #2233994
01/14/17 01:49 PM
01/14/17 01:49 PM
IL
E
EDG Offline
EDG  Offline
E
IL
I have one from Richard,works great. No need to remove the rockers. Give him a call he's a Cool Dude. Ed
Re: In car Hemi valve spring compressor [Re: SNK-EYZ] #2506604
06/10/18 02:36 PM
06/10/18 02:36 PM
Texas
P
peaver Offline
peaver  Offline
P
Texas
I've used the one made by Richard Trout. Worked good.
Even the exhaust side by the shock towers.
