dynomax 17747 ? #1655068
08/04/14 06:57 PM
08/04/14 06:57 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
Anyone with a 2 1/4 system running these ? They are listed as center in offset out and I want to run them in reverse on a 69 B body ???
Re: dynomax 17747 ? [Re: JohnRR] #1655069
08/04/14 07:11 PM
08/04/14 07:11 PM
Fort Lauderdale
Dave440 Offline
Dave440  Offline
Fort Lauderdale
Not using them myself but have been looking into a new system and done the research. They are reversible.
http://www.dynomax.com/super-turbo-centered-offset-576.html
Re: dynomax 17747 ? [Re: Dave440] #1655070
08/04/14 07:38 PM
08/04/14 07:38 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
Thanks Dave , I missed that part on the web listing
I did call dynomax and ask because I needed to place the order ASAP.
Re: dynomax 17747 ? [Re: JohnRR] #1655071
08/04/14 07:43 PM
08/04/14 07:43 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
John,been running that muffler on my bird since I've owned it,over thirty years,wouldn't use anything else.B-body is one of the applications,why would you want to reverse it? Also if you buy keep your receipt,you'll never have to pay for a replacement!
Re: dynomax 17747 ? [Re: JohnRR] #1655072
08/04/14 07:43 PM
08/04/14 07:43 PM
Fort Lauderdale
Dave440 Offline
Dave440  Offline
Fort Lauderdale
YW John... Overlooking something right in front of you? I've never done that!!
62Maxwagon...i've always wondered something about turbo mufflers. Wouldn't Offset/Offset flow better than Center/Offset? Maybe this would be better for a separate post and an opinion poll LOL... but it just seems logical looking at the cutaways of the tube layout, flow directors (if any) and internal perforated tube.
Re: dynomax 17747 ? [Re: Dave440] #1655073
08/04/14 07:55 PM
08/04/14 07:55 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
On a b-body you have to run then side inlet,center outlet,asked that question a long time ago and Walker says there is no difference.
Re: dynomax 17747 ? [Re: 62maxwgn] #1655074
08/04/14 08:01 PM
08/04/14 08:01 PM
Royersford, PA
bschargerse Offline
bschargerse  Offline
Royersford, PA
I had these mufflers on my '66 Newport 383 with the factory log manifolds and a full 2.25" system. No crossover pipe. There was a slight drone to it at cruising speed, but not too bad. It seemed as the muffler got older the less noticeable the drone.
Brian - 1971 Dodge Challenger
"The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
Re: dynomax 17747 ? [Re: JohnRR] #1655075
08/04/14 08:49 PM
08/04/14 08:49 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Ran the 747s ( more than one set) for a bunch of years on the 67. Worked fine. Went 12.80s and 90s at 109 with pretty stock motor, FWIW
Re: dynomax 17747 ? [Re: 62maxwgn] #1655076
08/04/14 09:23 PM
08/04/14 09:23 PM
Fort Lauderdale
Dave440 Offline
Dave440  Offline
Fort Lauderdale
"Walker says there is no difference."
Maybe negligible to them but there has to be a difference of some sort. I ran sonic turbo's for years offset/center and had no problem but always wondered about the flow.
I used the Dynomax offset x2 cutaway here and added exhaust (red/blue) to illustrate how it flows nicely with an offset setup and dual flow directors. I modified the cutaway to make a center/offset version which they don't show on their site. The exhaust has to dance around the chamber with the center tube before finding a way out (illustrated in blue). Center/offset obviously works and if the exhaust system can only acomodate that type of muffler then that's what we're stuck with...but I have seem some mopes with custom exhaust running offset x2. Be interesting to see a dyno showing the difference. Maybe worth a few horsepower?
