518 install, is there 1/2" "adjustment" of motor mounts
#1654660
08/03/14 08:15 PM
08/03/14 08:15 PM
Posts: 4,762 Florida
BDW
Installing 518 into 70 Challenger with 340. The speedo cable is blocked by the crossmember. Guy who built the crossmember says it sometimes happens because of the motor mounts. Is there at least 1/2" of front-to-back play in the motor mounts? Is it possible to loosen and push the whole thing back? Seems like a lot to move?
Re: 518 install, is there 1/2" "adjustment" of motor mounts
[Re: BDW]
#1654663
08/04/14 12:03 AM
08/04/14 12:03 AM
Posts: 18,160 Mass
DAYCLONA
Mass
The only way to get a 1/2" of rearward movement from the motor mounts, is to remove them from the engine, re-bolt the mount brackets to the front of the engines ear tabs, that should give you about 5/8" rear movement.....but keep in mind there may be interference moving the engine this way?...depends on a lot of variables you need to look at, linkage, fresh air induction, etc, etc, I'll assume your shortening the drive shaft?
Mike
[Re: BDW]
#1654665
08/04/14 11:36 AM
08/04/14 11:36 AM
Posts: 18,160 Mass
DAYCLONA
Mass
[quote Moving the mounts on the engine sounds possible. What about redrilling the motor mount to shift the position of the insulator? I'm not sure what the mount looks like apart. Anyone have pics or experience with this? There's actually more room than I thought, but this speedo problem popped up. It's never easy is it? Thanks for the replies
Why drill?....I just offered you a "bolt-on" solution, if it don't work, just un bolt it, and re bolt it back on...1/2 hrs work at most
Mike
[Re: BDW]
#1654666
08/04/14 11:52 AM
08/04/14 11:52 AM
Posts: 15,487 Florida
scratchnfotraction
could the xmember be cut/notched/trimed to allow the cable to fit the speedo output? unhooked it will keep miles from adding up on the odometer I cant see well enuff in the pic if it would be able to clearance any. I cut a xmember and welded in a pipe so the cable could go thru it one time on a mud truck. my self I would be looking to mod the xmember, not moving the engine back from stock location.
[Re: BDW]
#1654667
08/04/14 12:21 PM
08/04/14 12:21 PM
Posts: 12,327 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Could you share a little info on the cross member? Who built it and how much was it?
Thanks!
Master, again and still
[Re: DaveRS23]
#1654668
08/04/14 09:05 PM
08/04/14 09:05 PM
BDW
I only needed 1/4" or so, and I already have air cleaner / hood problems, so moving the motor back 5/8" wasn't my 1st option. I think I found something workable. Original 727 was at 0deg and rear-end is at 0deg, I know this isn't optimal and might be reason for annoying vibration at 70mph? So, I lowered the 518 tranny to -3deg, to clear hump brace. With the tranny at -3deg and rear-end at 0deg, the new set-up is a net -3deg? Not the desired -4-5deg, but better. I then notched the mount to allow the cable to connect. It's tight, so please don't tell me I have to worry about forth/aft movement? Thoughts?
[Re: BDW]
#1654669
08/05/14 12:50 AM
08/05/14 12:50 AM
scratchnfotraction
that's what I would have done. can you clearance it a bit more then maybe box/section the xmember where you have it notched. like slicing a pipe in 1/2 then weld it in to fill the backside of the notch. looks good in the pics.
[Re: BDW]
#1654672
08/05/14 11:27 AM
08/05/14 11:27 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
$367 for the mount and then you have to clearance it for the speedo cable. Now if we could just get the bells for the big blocks.
[Re: BDW]
#1654676
08/05/14 01:59 PM
08/05/14 01:59 PM
scratchnfotraction
it is gonna drive you bannanas for a week Huh? I will go check the 727 and see which way the different tooth count moves the pionion around in the hole and let you know. do you know the tooth count in the 518 now? what rear axle gear tire size? IIRC, you should just swap gear from the trans coming out to the 518 so no biggie there. waiting a week to know which way it moves...
[Re: Rick_Ehrenberg]
#1654678
08/05/14 03:33 PM
08/05/14 03:33 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
Were you able to avoid cutting the torsion bar crossmember at all? That's pretty cool for installing a 518 in an e-body, but how far down does the rear of the motor/trans drop from stock?
I found these other pictures on Fontana's Facebook page.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#1654679
08/05/14 03:34 PM
08/05/14 03:34 PM
jbc426
West Coast, USA
...and the transmission.
ps: You can buy a speedometer extension of either size you want on ebay. Just do a quick search.
