hemi shaker base feet location needed #165455
12/10/08 02:33 PM
12/10/08 02:33 PM
Canada
W
westfort Offline OP
westfort  Offline OP
W
Canada
does anuone have the demension to locate the hemi support feet that are welded to the baseplate for the 70 71 shaker
thanks
Re: hemi shaker base feet location needed [Re: westfort] #165456
12/11/08 06:56 PM
12/11/08 06:56 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
I know it ain't a Hemi, but they should sit on the top edge of the valve cover closest to the intake.
Re: hemi shaker base feet location needed [Re: Kudakidd] #165457
12/11/08 09:15 PM
12/11/08 09:15 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
You can thank Terry (aka mccannix) for this information.
Re: hemi shaker base feet location needed [Re: Snoopy] #165458
12/11/08 09:16 PM
12/11/08 09:16 PM
Snoopy Offline
Snoopy  Offline
This is from the 70-71 Factory Parts Book.
Re: hemi shaker base feet location needed [Re: Snoopy] #165459
01/01/09 03:08 PM
01/01/09 03:08 PM
Snoopy Offline
Snoopy  Offline
Is there one or two feet on the base?
Re: hemi shaker base feet location needed [Re: Snoopy] #165460
01/01/09 04:47 PM
01/01/09 04:47 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Hi Snoopy...There's two....But the 383 version had a single "foot"... Here's an old pic that Scott Smith had posted a few years ago from an original set-up...You can see the feet across from each other...
Re: hemi shaker base feet location needed [Re: screamindriver] #165461
01/01/09 05:43 PM
01/01/09 05:43 PM
Snoopy Offline
Snoopy  Offline
That's what I thought, but I couldn't prove it with any information I had available. When I bought the feet from Terry, he supplied 2 brackets and 2 feet but his instructions only showed the location of 1 foot. The parts book only shows 1 foot. Is the other foot located directly opposite the one I have shown in Terry's sketch?
Re: hemi shaker base feet location needed [Re: Snoopy] #165462
01/01/09 07:10 PM
01/01/09 07:10 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I have an original that someone tore the feet off of at some point, but the old spot welds are still visible. I'll take a pic tonight when I get off work.
Re: hemi shaker base feet location needed [Re: Snoopy] #165463
01/01/09 11:59 PM
01/01/09 11:59 PM
Harrisburg, Pa.
Harrisburg, Pa.
Yes, they're a mirror image of each other...I was looking through my prints and can't find the complete page to this FAD...Do you have this page ?? ..
Re: hemi shaker base feet location needed [Re: screamindriver] #165464
01/02/09 12:09 AM
01/02/09 12:09 AM
Harrisburg, Pa.
Harrisburg, Pa.
And I did find another pic of the original set-up that Scott Smith had submitted...I have this one listed as early 05 thread... It's my understanding that they are welded in the same location{on the base} 6-bbl and hemi but the secondary bolt-on pieces are different between them...
Re: hemi shaker base feet location needed [Re: screamindriver] #165465
01/02/09 12:56 AM
01/02/09 12:56 AM
Snoopy Offline
Snoopy  Offline
I found the print you referenced, but it doesn't show the second foot. It does however mention it in the "M" note shown in your picture.
Thanks for taking the time to look for the additional information.
Re: hemi shaker base feet location needed [Re: screamindriver] #165466
01/03/09 02:12 PM
01/03/09 02:12 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Snapped this photo this morning. You can see what's left of the original feet. Some moron twisted them off many decades ago.
Re: hemi shaker base feet location needed [Re: jbc426] #165467
01/03/09 04:01 PM
01/03/09 04:01 PM
Snoopy Offline
Snoopy  Offline
Thanks for the photo.
Here is a copy of the engineering print.
Re: hemi shaker base feet location needed [Re: Snoopy] #165468
01/03/09 07:27 PM
01/03/09 07:27 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
A little known fact is that the feet and brackets were actually scheduled to be deleted on the 440-6 shaker base for the 1971 model year.
I dont think it actually took place on the date shown in this Fram print, but it may have at some time in production.
This would account for the reason that a lot of NOS 440-6 shaker bases have no support brackets.
Re: hemi shaker base feet location needed [Re: mccannix] #165469
01/03/09 08:17 PM
01/03/09 08:17 PM
Snoopy Offline
Snoopy  Offline
Terry,
I have an NOS Hemi Shaker base plate that doesn't have the feet. Thanks for locating a set for me.
Re: hemi shaker base feet location needed [Re: Snoopy] #165470
01/03/09 08:47 PM
01/03/09 08:47 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
NO problem Snoopy...
I believe most NOS 440-6 pak and Hemi shaker bases, which were actually just overrun for Chrysler's inventory, were shipped from Fram with no feet brackets installed.
Because they carried a separate part number, you were expected to order them and install yourself.
Re: hemi shaker base feet location needed [Re: mccannix] #2689672
08/20/19 09:56 AM
08/20/19 09:56 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
So I have the feet but not the brackets. Where might someone find a set?
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: hemi shaker base feet location needed [Re: MOPARMIKE69] #2689676
08/20/19 10:22 AM
08/20/19 10:22 AM
California
biggE Offline
biggE  Offline
California
Contact Mccannix. I believe he still has some
Re: hemi shaker base feet location needed [Re: biggE] #2689678
08/20/19 10:28 AM
08/20/19 10:28 AM
MD
floyd Offline
floyd  Offline
MD
If Terry doesn't have them, Frank Badalson has repros:
http://www.rogergibsonautorestoration.com/FileStream.aspx?FileID=1
