B1-MC #1654407
08/03/14 12:28 PM
08/03/14 12:28 PM
Mo.
supercomp Offline OP
Mo.
How much lift can you get with B1-MC heads before needing longer valves when using spring cups? I was told they quit making power at .825 lift. True or not. My programs disagree.
Re: B1-MC [Re: supercomp] #1654408
08/03/14 11:27 PM
08/03/14 11:27 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I had .930 gross lift on the intake side on my 540. It didn't work out too well though. It needed a converter that flashed 6600.
Re: B1-MC [Re: camastomcat] #1654409
08/04/14 11:46 AM
08/04/14 11:46 AM
Mo.
Mo.
Thanks Tom.
Re: B1-MC [Re: supercomp] #1654410
08/04/14 12:19 PM
08/04/14 12:19 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
The ones on the 499 are around .900 lift on both sides with 1.7 rockers. They didn't run out until well into the 8000's, if not more. I've seen 9300 and maybe more by mistake.
I don't know if these are MC, PSO, or what. I will try to get some clarification from Adger Smith when the heads get back to him to be freshened up. He built them originally when he built the engine for the Hardesty's.
Re: B1-MC [Re: Airwoofer] #1654411
08/04/14 12:46 PM
08/04/14 12:46 PM
Mo.
Mo.
This will be a 604 with 1.75 in 1.7 ex 55mm roller cam.
Re: B1-MC [Re: supercomp] #1654412
08/04/14 01:19 PM
08/04/14 01:19 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
We haven't taken out the cam yet so don't know if it is 55. The motor will need a different one as I probably destroyed the one it has (if the motor stays NA Adger has another that is pretty close) - and I really want to put a procharger on the motor and drive it on the street / strip. There are no mounting bosses on the heads though if a side mount procharger needs them.
Re: B1-MC [Re: Airwoofer] #1654413
08/09/14 01:14 PM
08/09/14 01:14 PM
MO.
CROWBAR Offline
CROWBAR  Offline
MO.
Does any one have flow numbers for these heads to show what cam lift works best Have been told after 825 the flow goes negative Any help would be appreciated
Re: B1-MC [Re: CROWBAR] #1654414
08/09/14 01:46 PM
08/09/14 01:46 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mine were pulling fine past .900" lift. Peak was 457cfm on the few flow benches they were on. But mine were also an oval port design. Not the conventional, and what I generally see giant rectangle design everyone seems to love. Old school thinking IMO.
Re: B1-MC [Re: Al_Alguire] #1654415
08/09/14 01:55 PM
08/09/14 01:55 PM
Mo.
Mo.
Thanks Al Who done your heads.
Re: B1-MC [Re: supercomp] #1654416
08/09/14 02:29 PM
08/09/14 02:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My M/Cs were suppose to flow 465 according to Modern
Cyl Head which did the port work.. I never flowed them
on another bench to verify the numbers(that was the
standard port design)
Re: B1-MC [Re: MR_P_BODY] #1654417
08/09/14 02:36 PM
08/09/14 02:36 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I know we don't race dynos or flow benches but my junk seemed to run ok. Dyno was 1050, IMO a tad conservative. The car went 10.90 at 161 and change at 2975lbs. That takes some HP to do.
The heads were ported by Mike Duke.
Re: B1-MC [Re: Al_Alguire] #1654418
08/09/14 03:29 PM
08/09/14 03:29 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
He is a REAL cylinder head guy. Understands there is more to it than make it BIG.
Monte
Re: B1-MC [Re: Al_Alguire] #1654419
08/09/14 03:34 PM
08/09/14 03:34 PM
Mo.
Mo.
Thanks for all the replies guy's.
Re: B1-MC [Re: Monte_Smith] #1654420
08/09/14 03:35 PM
08/09/14 03:35 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well have a set at another well known, non Mopar cylinder head shop right now. They think there is even more to be had. Time will tell if that holds true.
Kinda like the Predator deal I am doing now. I have some very smart people helping with the deal. Non Mopar guys of course but they all have very good track records making power in everything from SS and Comp to PS.
Re: B1-MC [Re: Al_Alguire] #1654421
08/09/14 07:10 PM
08/09/14 07:10 PM
MO.
CROWBAR Offline
CROWBAR  Offline
MO.
Does anyone know how to get in touch with Mike Duke? Thanks
Re: B1-MC [Re: Al_Alguire] #1654422
08/10/14 10:54 AM
08/10/14 10:54 AM
Mo.
Mo.
What do you do for an intake? How do I get in touch with Mike Duke?
Re: B1-MC [Re: supercomp] #1654423
08/10/14 02:23 PM
08/10/14 02:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My intake was our of the box except the port opening was modified for the oval port and some minor blending on the carb pad. Here is the phone number I have, you can call and leave a message or text Mike at 317-435-5088. Texting seems to be preferred method. He is a one man deal so be patient. He is located in Indy I believe the shop number is (317) 783-4628 once again LEAVE A MESSAGE.
Re: B1-MC [Re: Al_Alguire] #1654424
08/10/14 03:27 PM
08/10/14 03:27 PM
Mo.
Mo.
Thanks Al
Re: B1-MC [Re: supercomp] #1654425
08/10/14 09:27 PM
08/10/14 09:27 PM
MO.
CROWBAR Offline
CROWBAR  Offline
MO.
Many Thanks Al Always A Big Help With Your Info Will Give Mike A Call Do U Have Any Photos Of The Oval Ports?
Re: B1-MC [Re: MR_P_BODY] #1654426
08/11/14 11:09 AM
08/11/14 11:09 AM
Farmington Hills, Mich
Chuck@Best_Machine Offline
Here you go Mike, I found this for you
