Drum brake vibration after they heat up, fine when cool #1654347
08/03/14 05:00 AM
08/03/14 05:00 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
I have a 72 Dodge Dart, My car has a vibration when hot & above 50mph when slowing down, & you can fell a little vibration wall driving when their heated up & it seems like in front... So after first time it happen I put new wheel bearings in, new brake shoes all the way around & took my front drum off to have them turned, seemed better, but adjusted up wear they should be, steel had small vibration when hot, so I back them off some & steel had ok brakes, drove it some then on passenger side brakes got squeaky, then load squeaky, so took a look at brakes, pulled passenger side off it had a lot of brake dust in bottom of drum, driver side not much, so I'm thinking little brake drag on one side because of old brake springs, so I put new brake springs on both sides...& now its got low squeak, back the way it was, vibration when adjusted up when hot slowing down at above 50mph! My passenger side drum lug nut stud holes are bent out some, could that be the prob.? If its not that, then I'm thinking out of round drum!
What do you guys think?
I have pics, but look over cotter pin missing because I tried readjusted wheel bearing also & steel like putting it in when took a pic!
Re: Drum brake vibration after they heat up, fine when cool [Re: Hoop] #1654348
08/03/14 05:02 AM
08/03/14 05:02 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
pic2
Re: Drum brake vibration after they heat up, fine when cool [Re: Hoop] #1654349
08/03/14 05:03 AM
08/03/14 05:03 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
pic3
Re: Drum brake vibration after they heat up, fine when cool [Re: Hoop] #1654350
08/03/14 05:06 AM
08/03/14 05:06 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
pic4.. all pics is of the passenger side!
Re: Drum brake vibration after they heat up, fine when cool [Re: Hoop] #1654351
08/03/14 08:24 AM
08/03/14 08:24 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Take the drum somewhere to be turned or replace it.....or swap it w another drum is the only way to test your idea.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Drum brake vibration after they heat up, fine when cool [Re: HemiRick] #1654352
08/03/14 09:28 AM
08/03/14 09:28 AM
moparx Offline
moparx  Offline
the drum should be swedged to the hub with the studs. it's possible that now the hub is bent as well as the drum mating surface. the proper way to turn the front drum to true it up is with the hub attached. you need to indicate the hub to see if it's true, then more than likely, get a new set of drums. if there is more than about .003-.005 runout on the hub mounting surface, you will need hubs as well.
Re: Drum brake vibration after they heat up, fine when cool [Re: Hoop] #1654353
08/03/14 12:24 PM
08/03/14 12:24 PM
new drums swedged onto the hubs. www.classicindustries.com has a nice selection with good prices or some good uses ones (drum/hub assy)
Re: Drum brake vibration after they heat up, fine when cool [Re: RapidRobert] #1654354
08/03/14 12:28 PM
08/03/14 12:28 PM
Central New York
bfury Offline
bfury  Offline
Central New York
Sounds like the drums have already been turned and are too thin. Time too replace.
No Stock
Re: Drum brake vibration after they heat up, fine when cool [Re: RapidRobert] #1654355
08/03/14 02:48 PM
08/03/14 02:48 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
So they have swedged for 72 a-body, the one in the pic don't look swedged. & I know they made two size of 10" is it the one I need?
My Max Dia. 10.090
http://www.classicindustries.com/product/mopar/parts/2932.html
Re: Drum brake vibration after they heat up, fine when cool [Re: bfury] #1654356
08/03/14 03:13 PM
08/03/14 03:13 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
Makes sense...machined cold...distort when hot...variable thicknesses around the drum...hence variable expansion...the more thinner; the more so...My $0.02
Re: Drum brake vibration after they heat up, fine when cool [Re: bfury] #1654357
08/05/14 12:04 AM
08/05/14 12:04 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
So classicindustries.com Drums for a-body's are swedged???
Now I'm debating classicindustries.com or Advance Auto if they have them, web site shows they do!
On classicindustries.com is the drum inside edge the same wideness, looks thinner in pic!
http://shop.advanceautoparts.com/p/wagne...drum#fragment-1
Re: Drum brake vibration after they heat up, fine when cool [Re: Hoop] #1654358
08/05/14 10:29 AM
08/05/14 10:29 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
All Mopar drums on frt were swedged.Same with the early type thru 64 rears.Had some idiot pull drums off of the hubs on a 61 we bought.They were so bad that the pedal actually almost pushed your foot off when you hit the brakes.We had the swedge tool at work years ago.I wish I had got it along with other stuff they trashed when we closed the shop.Ever though about going discs on the front?You will never use drums again.Rocky
Chrysler Firepower
Re: Drum brake vibration after they heat up, fine when cool [Re: therocks] #1654359
08/07/14 05:00 PM
08/07/14 05:00 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
I wonder how the Swaged tool worked & can ya get a old one off ebay?
Re: Drum brake vibration after they heat up, fine when cool [Re: bfury] #1654360
08/07/14 07:39 PM
08/07/14 07:39 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Well I may just go with classic industries because Advance Auto don't have 10" no more, they just have not took them down from web site, but I would haft to call classic industries & find out if Max Dia. is 10.090, I e-mail last night, but they have not got back with me yet!
