Removing the console in 65 sport fury #1654181
08/02/14 08:03 PM
08/02/14 08:03 PM
Wisconsin
FFwithRT Offline OP
FFwithRT  Offline OP
Wisconsin
where are the bolts/screws that need to be taken out to remove my console? (1965 Sport Fury 4-speed) Thanks in advance, Greg
ffgreg32@aol.com
Re: Removing the console in 65 sport fury [Re: FFwithRT] #1654182
08/02/14 08:58 PM
08/02/14 08:58 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
If you lift up the flap on the bottom edge of the carpet you'll find 2 screws on each side front and rear. The front one is just forward of the shifter handle/side bump and the rear one is right at the back end of the console.
Mike
Re: Removing the console in 65 sport fury [Re: 1E2C] #1654183
08/02/14 10:25 PM
08/02/14 10:25 PM
Wisconsin
FFwithRT Offline OP
FFwithRT  Offline OP
Wisconsin
Thanks Mike
Re: Removing the console in 65 sport fury [Re: FFwithRT] #1654184
08/06/14 12:19 AM
08/06/14 12:19 AM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Oh yeah, you don't need to take the screws all the way out, the holes are open bottomed or slots in the console so if you just loosen them a few turns the console will lift off.
