difference on 915 heads #1654075
08/02/14 02:12 PM
08/02/14 02:12 PM
wisconsin usa
moretork03 Offline OP
wisconsin usa
what is the difference between the 915-2 heads and the 915-3, from what i see they are both numbered 2780915 -
Re: difference on 915 heads [Re: moretork03] #1654076
08/03/14 10:25 AM
08/03/14 10:25 AM
NJ
rth Offline
rth  Offline
NJ
I think the size of exhaust valve. Any machine shop can open it up to install bigger valve.
Re: difference on 915 heads [Re: moretork03] #1654077
08/03/14 11:29 AM
08/03/14 11:29 AM
it might be that whenever Ma changed the sand casting mold that the -number on the end was bumped up to the next number. The heads are identical & afaik the only difference is some 915's had the 1.60 ex valve (maybe the 375 horse HP versions got the 1.75 valve)
Re: difference on 915 heads [Re: RapidRobert] #1654078
08/03/14 01:29 PM
08/03/14 01:29 PM
wisconsin usa
wisconsin usa
mine are -3 and have the bigger ex valve but not sure if they were added or not, was just curious thanks
Re: difference on 915 heads [Re: moretork03] #1654079
08/03/14 01:57 PM
08/03/14 01:57 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
The big block 915 was the same basic casting, just machined 2 different ways, the 350hp got the 1.60 exh, the 375hp got the 1.74.
The 915 small block head was also the same casting, just machined 3 different ways, 1.88 int, 2.02 int, 2.02 int with relocated push rod holes.
Don't worry about the dash #, block castings also had them. There was some thought the lower dash # had less core shift but I believe that has been disproved.
Re: difference on 915 heads [Re: moretork03] #1654080
08/04/14 02:45 PM
08/04/14 02:45 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
The 1.74 exhaust valve heads usally came stamped "HP". Either a large stamp on the alternator mounting flange or a small stamp under the intake runners.
Re: difference on 915 heads [Re: R/T1968R/T] #1654081
08/04/14 06:31 PM
08/04/14 06:31 PM
dogdays Offline
dogdays  Offline
To repeat.....Casting numbers have NO BEARING on how the casting was machined.
R.
Re: difference on 915 heads [Re: R/T1968R/T] #1654082
08/04/14 10:01 PM
08/04/14 10:01 PM
All the big exhaust valve 915 csting(not very many )I've seen had the HP hand stamped on the end of both heads on the raised alternator mount boss
