OK so technically its a test-N-tune event tomorrow but im going to see how well the barracuda hits pylons and I am stoked!!
After barely moving the car for the last 18 months and it being on jack stands since last September, its finally together and driving ! Its a shame that I have neglected it so but work/life/locally competitive autox (SRT4) pretty much stole me away from working on it.
It turns out i had several problems caused by the previous owner including un-tight LCA pins and wallowed out kframe LCA tubes, not to mention the 73+ K frame with too long 72- old style strut rods. So in the last Two weeks:
installed welded/reinforced/painted 73+ K frame
correct length strut rods, with bushing adjustments
reinforced LCA w\urethane bushings
FFI UCAs
1.125" FSB that ive owned for 4 years
0.75 RSB owned 2 years
1.03 torsion bars
Wilwood prop valve to tame the giant 11x2.5" rear drums & 15/16" cylinders. balance is good but i still need smaller wheel cylinders.
SRT4 front drivers seat. pass seat mount pending
Sure-grip /rear axle seal freshening
new brake hoses
OK~ish driveway alignment. lots of caster and ~-2 deg camber 1/16" toe in.
17x8 wheels and mounted nearly NEW 225/45 Dunlop ZII's (got great deal!)
I even put some real road miles on the car so im not surprised by something stupid.
props to the previous owner manual disk brake setup with DOT 5. It really does work well with good pedal modulation and everything came out crystal clean even though this was the first time the brakes have been open since i bought it in 2009.
Still needs some things done on the list but the goal really isn't an all out competitive autoxer, Im just trying to get a baseline. But who knows its already turning better than i was expecting.
