Miles Per Gallon and other questions #165376
12/10/08 12:38 PM
12/10/08 12:38 PM
Anonymous OP
Anonymous OP
How many miles per gallon does a 1971 340 plymouth duster get? Here are the specs.
650 cfm carb
1971 340 block
.30 over 10 1/2 to 1 compression pistons
stock steelcrank
edelbrock airgap intake
mopar purple cam shaft 484 lift
360 j heads (small valve)
727 trans with shift kit
7 1/4 non posi rear
Would i see a big performance increase if i but 340 x heads on this car with a 8 3/4 posi rear?
Re: Miles Per Gallon and other questions #165377
12/10/08 12:48 PM
12/10/08 12:48 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
what gear?
Re: Miles Per Gallon and other questions [Re: DJVCuda] #165378
12/10/08 12:52 PM
12/10/08 12:52 PM
Anonymous OP
Anonymous OP
I honestly dont know. The trans is automatic. When im doin 60-70 mph the tach says 2700-3000 rpms.
Re: Miles Per Gallon and other questions #165379
12/10/08 12:54 PM
12/10/08 12:54 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Some 340s do real well while others not so good. I've heard of over 20mpg and under 12mpg on the highway. State of tune, cam, and gears have a lot to do with it.
Re: Miles Per Gallon and other questions #165380
12/10/08 01:16 PM
12/10/08 01:16 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
wow 4 1/4 rear be careful. my 72 swinger had a mild 340, 10:1 stock 340 cam w/ 1.6 rollers, headers rpm air gap and a 750 holley dp, 727 and 3.91's. I could pull 17mpg highway at 65-70.
Re: Miles Per Gallon and other questions [Re: Mr.Yuck] #165381
12/10/08 01:53 PM
12/10/08 01:53 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
you won't see a noticable power difference between the J and X heads.
you might see an appreciable performance improvement by going to a different gear ratio (say from a 3.23 to a 3.91), but you might sacrafice fuel economy and comfort (buzzing along at 3300-3500 at freeway speeds vs. 2700-2900)
that cam, you'll be lucky to get much better than ~13mpg....
2017 Grand Cherokee Overland
Re: Miles Per Gallon and other questions [Re: patrick] #165382
12/10/08 02:09 PM
12/10/08 02:09 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
With the RPM speed and the MPH given I would say that you have a 3.23 gear given the low and high RPM and low and high MPH.
I had a pure stock 71 that I bought new with a 3.91 factory installed and at 65/70 it would pull an honest 15-16 on the highway on a trip.
Re: Miles Per Gallon and other questions [Re: MoparforLife] #165383
12/10/08 02:12 PM
12/10/08 02:12 PM
Anonymous OP
Anonymous OP
youve got the 284/484 cam in there. I ran that with 3.91's and a 3000 stall converter and got between 7 and 9 mpg. looks like you have 3.23's so you'll do a bit better. I'd say 8 to 10 mpg
Re: Miles Per Gallon and other questions #165384
12/10/08 05:51 PM
12/10/08 05:51 PM
okla.
O
okie Offline
okie  Offline
O
okla.
I've got about the same motor with 323 gears but I'm running a 750 Edlebrock carb and it's not too good and I get around 10 MPG's out of it. The carb isn't good and it hasn't been since it was new and I've got a new Carter to put on it and I think it will do a lot better then. Good Luck! Ronnie in Okla.
Re: Miles Per Gallon and other questions [Re: okie] #165385
12/10/08 06:24 PM
12/10/08 06:24 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
with a 7¼ rear you don't have likely more than a 3.23...probably less. IIRC, the LSA on MP's hydraulic cams really sucks for mileage, but it's been awhile.
hotroddave40's mileage thread in the Projects section has some really good info for choosing parts with mileage in mind.
And changing your heads would be a colossal waste of money. Except in extreme (7K+ rpm/race) scenarios, you will not see enough improvement going to a 2.02 head from the 1.88's...likely none at all.
2 Demons...no, not my kids!
Re: Miles Per Gallon and other questions [Re: 4speeds4me] #165386
12/10/08 07:29 PM
12/10/08 07:29 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
That cam is killing you. If there's one thing the 284/484 was not made for, it's fuel mileage. That's a big cam for a small block and it's got a narrow LSA. You'll never get good mileage with it.
Re: Miles Per Gallon and other questions [Re: DaytonaTurbo] #165387
12/11/08 02:59 PM
12/11/08 02:59 PM
Simi Valley, CA
MoparJ Offline
MoparJ  Offline
Simi Valley, CA
I am pulling 16-18 mpg out of mine at 65 mph on the hwy, with 26.5" tall tires, 3.21 gearing, and a stock converter. It turns about 2700 rpm at that speed. The motor is a 73 318, with stock compression replacement pistons, stock heads, Comp XE268 cam, headers, 2.5" exhaust, and a holley 600 carb on a performer intake.
The trans is a 904. I am hoping the milage might make an uptick when I move up to a looser 2-2,200 stall to complement the performance gain.
I have a fairly large cam, but that 284 is even bigger.
The relatively stock 70 340 with J heads in my 340 Formula S 69 Cuda pulls about 15-16 with 3.23s and a 2000 stalled 727. The manifold is stock and the carb is a worn out Edelbrock performer 600 cfm.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: Miles Per Gallon and other questions [Re: DaytonaTurbo] #165388
12/11/08 10:54 PM
12/11/08 10:54 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I think the 8 to 10 mpg estimates are pretty close. Still better than the 6 to 7 I get
I doubt you'de see a perf gain from the heads, but it's hard to say. Has either set been ported>
The ring gear size won't gain you anything. It's the ratio. Stick with a sure grip instead of GM posi unit though.
An upgrade to an 8 3/4 is probably a necesity, simply from a strength standpoint. I had a friend with an aspen with a 340 in it. It broke a couple of those 7 1/4's in really short order.
Re: Miles Per Gallon and other questions [Re: dave571] #165389
12/12/08 05:14 PM
12/12/08 05:14 PM
Saskatoon Sk, Canada
Mark340A66 Offline
mopar addict
Mark340A66  Offline
mopar addict
My old stock 70 340 4spd A66 Challenger with 3.23's, a good working vac. advance system and a real sweet 800 TQ was getting 18 US MPG/22 Imp at 65-70. Before the TQ, I had an AFB 625 that got 2-3 MPG less. Bring on the Thermobog bashers! I sold the car and kept the TQ (#1966 rods)
Mopar or No Car: Sold Nov/06 1970 Challenger 340 4bbl (A66 code), A833 4 speed, 3.23 SureGrip all numbers match. 03 Dodge SX 2.0 R/T 2.0L HO(CDN Neon R/T) Black w/Grey Leather, Sunroof
Re: Miles Per Gallon and other questions [Re: Mark340A66] #165390
12/12/08 07:27 PM
12/12/08 07:27 PM
Simi Valley, CA
MoparJ Offline
MoparJ  Offline
Simi Valley, CA
Thermoquads= small primaries for fuel savings, huge secondaries for power. Great carbs when set up right.
Re: Miles Per Gallon and other questions [Re: MoparJ] #165391
12/12/08 07:38 PM
12/12/08 07:38 PM
Upper Midwest
Upper Midwest
Unless the combustion chambers on the X heads are smaller or the heads are ported to flow better than the 1.88 heads you will gain nothing with the switch. In fact you could go the other way and loose slight low end performance unless you are going to run in the higher RPM range. (like 6000+)
Re: Miles Per Gallon and other questions [Re: MoparforLife] #165392
12/12/08 07:48 PM
12/12/08 07:48 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
With your current setup, try out a TQ I've got a new rebuilt one that is on the way now, and I've run one before on a mild 360. The fuel mileage versus other carbs is quite noticeable, especially when compared to any Holley that I've run
Re: Miles Per Gallon and other questions [Re: 68Bullit] #165393
12/12/08 08:41 PM
12/12/08 08:41 PM
Outside
thedriver Offline
thedriver  Offline
Outside
i used to daily drive a BONE stock '70 340 duster. the only change it had was a thermoquad over the factory afb. it had 3.23 gears and 205/70/14's that car would get me 18mpg on the hiway at 65mph. very respectable for what it was really.
1973 challenger
Dana. 4 speed. Low deck.
Re: Miles Per Gallon and other questions #165394
12/12/08 10:13 PM
12/12/08 10:13 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
A stock 71 340 with a correctly setup Thermoquad carb(800 or 850) and distributor can achieve at 20 mpg highway with 3:23's. To be honest, mid twenties wouldn't surprise me. The 284 MP cam will knock that down quite a bit.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Miles Per Gallon and other questions [Re: thedriver] #165395
12/12/08 10:21 PM
12/12/08 10:21 PM
Ottawa, ontario
dd340 Offline
dd340  Offline
Ottawa, ontario
Under ideal conditions, warm day, flat road, continous driving at 60mph i have gotten an honest 20US mpg, closer to 26 imp mpg. I have the 600 eddy carb and it is tuned lean at cruise, cam is a fairly small 268* and 3.23 gears with an auto and stock convertor with stock exhaust setup. It's not a dog either cause it wil run a 13.7 in the 1/4. I think the secret to good mpg is a fairly small overlap cam and lots of compression. That and a properly tuned carb.
